Anti-Theft System has Shut Car DOWN
Old Feb 26, 2020 | 05:08 AM
Michaels's Avatar
Default Re: Anti-Theft System has Shut Car DOWN
Ive just gotten out of 3 months of hospitalization. I put a friend with a Mercedes in charge of finding repair for this. Now after all this I remembered you all are here to which I am entirely grateful. Thanks
Old Feb 26, 2020 | 05:09 AM
Michaels's Avatar
One or more of what companies listed above? Having hard time following.
Please LIST 3 Companies in reply.
Much appreciation,
Suzanne
Old Feb 26, 2020 | 05:13 AM
Michaels's Avatar
I watched the SKREEM video you provided in your message AND THAT IS EXACTLY WHAT MY CAR DID.
TWO QUICK STARTS THAT STALLED and then zip. I emailed the Wings Dealership before I went to sleep.
Thank you ALL so very much.
Suzzanne
Old Feb 26, 2020 | 08:39 AM
Rob at Needswings.com should be able to help you
Rob is a long time member and reputable business owner here
Old Feb 26, 2020 | 10:24 AM
Jim Holian's Avatar
michaels - the other two companies mentioned in the post's are SOS in Oregon and MDP in Florida. Since you are laid up I will see if I can find any information or website address for you. Perhaps someone else also has that information. Valk (moderator) has a lot of information on various companies mentioned on this site.
Jim
Old Feb 26, 2020 | 11:00 AM
Jim Holian's Avatar
michaels - all I could find was SOS Automotive in Portland, Oregon and MDP-services.com in Florida. I don't know if these are the companies mentioned. Maybe someone else know's. If it were me, I'd go to Rob at Needswings. He's been around for quite a while and knows what he's doing.
Jim
Jim
Old Feb 26, 2020 | 11:09 AM
Jim
Jim
These are the two other companies that can repair our SKREEM modules according to others here on the forum that have used both of them successfully
It does require someone to remove other parts from your car and send them to these two companies in order for the module to be repaired
https://mdp-services.com/
http://sosdiagnostics.com/crossfire.html
Old Feb 26, 2020 | 11:24 AM
Michaels's Avatar
SKREEM Modules BACK-ORDERED SINCE JUNE according to Rob at NeedWings.com
I called and spoke with Rob this morning in detail about everything the shop I took it to has done and is charging me for.
He says theyre not out of line at all, they are right on track, that in order to diagnose Crossfires you need a $20K Mercedes laptop and software to do so, thus the additonal $300.
Also, in addition to the SKREEM module, there is a box the size of a brick located in the trunk that is connected to the SKREEM unit that controls door entry which may have gotten wet and burnt out.
He also mentioned that if the electronics in my key fob had gone bad, that could be the WHOLE problem from the get go.
When I purchased the car used in 2009, it only came with one key fob, then in 2014 I lost the fob completely and ordered a new one for $300 from MOpar directly which took a week to get.
All in all, Rob said Used SKREEM units were no good because they had to be in coordination with the cars VIN, which I sent him and am now on a waiting list for, and until God knows when?
I can't believe this is all so difficult ;(
I'll check back for more updates of course, because if anyone can find a solution, it's all of you.
Much appreciation,
Suzzanne
Old Feb 26, 2020 | 11:57 AM
Michaels's Avatar
Valk,
Repairing? SKREEM Modules? What about this box in the trunk that Rob's referring to too? Familiar with what that?
Please be a little more specific when able. In the meantime Im going to email the 2 other sites listed on here.
Thanks
Old Feb 26, 2020 | 12:34 PM
Originally Posted by Michaels
Valk,
Thanks
It's all rather complicated even for me to understand fully.
There is a box with more electronics located on the right side of the trunk in the floor and if it gets wet I know it can affect the operation of the locks etc.
I don't believe that this component itself would cause the symptoms you have described of the two engine start ups and then nothing.
I have heard if this occurs and you disconnect your battery for a few moments and reconnect it you will get the same series of two times start and die and then nothing again.
It still sounds like the SKREEM module inside the dash behind your speedometer as shown in the video in my previous post.
I'm sorry I wish I could help you more.
Old Feb 26, 2020 | 12:39 PM
Rob can replace them and SOS or MDP can repair them. They also currently have replacements available.
Old Feb 26, 2020 | 12:42 PM
Michaels's Avatar
I spoke to Rob 2 hours ago.
I typed out our whole conversation regarding his answers to all in a post on here too
He can't do anything besides put me on a back order list that's since June : (
Im in the process of visiting the other 2 recommended for repair sites now.
Thanks
Old Feb 26, 2020 | 12:47 PM
Michaels's Avatar
You're the best.
Thank you for your time : )
Old Feb 26, 2020 | 12:52 PM
Michaels's Avatar
Jim,
I took your and Valk's advice and am having the shop here send my SKREEM to one of your recommended shops to see if they can repair it.
I will post the shop I chose and the outcome of all when I'm back up and running as to help others that may come along here that may need this information down the road, too.
Thanks again for all your replies and links.
Suzzanne
Last edited by Michaels; Mar 4, 2020 at 12:45 PM. Reason: Update of Problem Solving Progress
Astrofriend
Dec 9, 2018 04:56 PM
shyloe
68
Dec 9, 2017 11:54 AM
zalsaigh
May 2, 2013 11:09 PM
ROBBIE2
Nov 6, 2012 07:21 PM
CrossfireLTD
Jan 6, 2005 12:11 PM
