Help clicking noise
Your lug bolts are too long,, they are hitting the E-brake cable,, i'll bet you put a different rim on the rear or a different offset, the 18 on the front offset is 35 the 19's on the rear are 25 ,,a lot thicker , the 35 offset 18" rim will only work on the rear (with the stock lugbolts) is with a spacer.jim
WingMan
Jul 31, 2008 06:59 PM
