What size tap needed to rethread wheel hub bolt holes?
Old Aug 7, 2020 | 12:49 PM
silenthooves's Avatar
Default What size tap needed to rethread wheel hub bolt holes?
Hi all – just a quick question for the forum collective.
Due to a sequence of events involving a tyre monkey with an enthusiastic rattle gun, I’ve got damage to some of the threads in both rear wheel hubs. The bolts will tighten but the threads on the bolts are being stretch in doing.
So I don’t have to replace wheel bolts each time I remove a wheel, and avoid having to replace the entire hubs, I want to try and re-cut the threads in the hubs.
Does anyone know what size tap & die I would need? And as I’ve not rethreaded anything before any useful advice/words of wisedom would be welcome (I shall obviously be consulting several videos on YouTube as well!), and apologises if this is a very novice/silly question!
Cheers
Old Aug 7, 2020 | 01:24 PM
Default Re: What size tap needed to rethread wheel hub bolt holes?
Cheers
Re-threading is not the answer at all, you need inserts put in the hub to replace the thread, Helicoil or Keenserts (which is my favoured option). It must be done accurately or the wheel will not bolt up tight with the ball on the bolt not aligning to the ball socket in the wheel, so it would have to be done in a vertical milling machine or similar.
What you have is weak, a new hub is probably the cheapest way out.
Old Aug 7, 2020 | 04:02 PM
Ronman's Avatar
Helicoil is mentioned by name in the Crossfire service manual!
Old Aug 7, 2020 | 05:02 PM
I know but Keenserts are my favourite, I have used them in the past and they blow Helicoils out of the water in my estimation.
Whatever is used it has to be done accurately.
CLICK
Old Aug 7, 2020 | 08:30 PM
I would agree with the recommendation to just purchase new hubs.
Old Aug 11, 2020 | 06:11 AM
Thanks to all for the input - looks like new hubs it might have to be!
Old Aug 11, 2020 | 08:03 AM
waldig's Avatar
Talking Re: What size tap needed to rethread wheel hub bolt holes?
With all my autocrossing and testing of the car early on, the hub threads were getting loose-sloppy and I installed helicoils in the rear hubs. Its important that you watch to see that the coils do not hit the parking brake hardware as they tend to be longer than the hub. Mine are doing fine years on, FYI. WW
ajr
Mar 5, 2015 11:31 AM
maxcichon
Nov 26, 2008 05:41 AM
mrphotoman
Nov 21, 2008 05:06 AM
Firstpoet
May 20, 2008 05:06 PM
bmerfan
Sep 23, 2004 07:57 PM
