Engine stops at Idle.
Old May 21, 2023 | 03:22 AM
Vader3's Avatar
Question Engine stops at Idle.
Occasionally, much too often for my tastes, after driving around I come to a stop and the engine quits for no apparent reason. I restarts immediately, so I have not been stuck, yet. I have replaced the crank and cam sensors and still no joy. My next step is to check the relays in the RCM for arcing. Anywhere else I should look? OBD scanner shows no faults at all. '05 base Coupe, 6 speed manual.
Thanks in advance.
Old May 21, 2023 | 08:09 PM
Romad's Avatar
Default Re: Engine stops at Idle.
Check your fuel pump pressure. Maybe yes maybe no for the cause! I "think" it's supposed to be 54-67 lbs pressure.
Old May 21, 2023 | 09:48 PM
Vader3's Avatar
I shall give that a go. Thx.
Old May 22, 2023 | 08:41 AM
zip439's Avatar
Thanks in advance.
The replacement sensors must be "Bosch" . Experience here on the forum has proven, anything else will develop into a problem.
Vipor3D
Sep 11, 2019 12:45 PM
jefftalexander
Dec 20, 2018 11:16 AM
ibedoughboy
Dec 19, 2012 08:40 PM
RapidFire
18
Sep 28, 2010 02:33 PM
srjgtott
May 29, 2006 05:25 AM
