Need help finding extended lug bolts for 20mm spacers.
Old Jun 6, 2023 | 01:17 PM
Couperacer's Avatar
Default Need help finding extended lug bolts for 20mm spacers.
Hey all, I want to put 20mm spacers on the rear of my coupe but I know that you need longer bolts, maybe an inch longer than the stock 1.5’s it comes with. I research everywhere and can’t find anyone who even makes a 12x2.5 lug bolt. Does anyone know where I can find some? Thank you. (Btw my spacers I bought didn’t come with bolts)
Old Jun 6, 2023 | 04:13 PM
Default Re: Need help finding extended lug bolts for 20mm spacers.
You might get more attention under "Wheels and Brakes"?
Old Jun 6, 2023 | 04:14 PM
Couperacer's Avatar
Actually I figured it out. Thanks
Old Jun 6, 2023 | 09:28 PM
CyberCG's Avatar
Inquiring minds want to know. What did you do?
Old Jun 8, 2023 | 09:11 AM
NeedsWings's Avatar
if you still need help we can get them for you
Old Jun 8, 2023 | 11:01 AM
To be more specific the OEM studs are 40mm, so you need 60mm studs. Working in inches just confuses the issue at times, so your 1" is actually 25.4 inches which is 5.4 mm too long.
The proper length of the studs is critical, too long and they hit the emergency brake mechanism.
Old Jun 8, 2023 | 11:11 AM
NeedsWings's Avatar
also need to account for if they are aftermarket rims which prompted the spacers in the first place
Old Jun 11, 2023 | 09:00 AM
Jack G's Avatar
For those who have to work in the inch system use the following simple metric length conversion operation:
1mm = .040" (.03937"), example - 60mm = .040" x 60mm = 2.4"
pholmes237@yahoo.com
Jun 10, 2018 09:16 AM
Teuton
Mar 26, 2011 06:56 PM
SoftballJunnkie
Mar 10, 2011 08:49 PM
Infinite
Feb 26, 2010 07:43 AM
former NXMX5
Jul 27, 2009 06:09 PM
