Door latch replacement question
Old Jul 13, 2023 | 07:13 AM
svtmerc's Avatar
Default Door latch replacement question
Has anyone ever replaced their door latch? I need to replace mine on the drivers door. I removed one from an SLK, but had to bend parts of the inner door structure to remove it. Pretty sure the manufacturer didn't have that problem installing it... lol
Anyone have any instructions/tips?
Old Jul 13, 2023 | 11:31 AM
Default Re: Door latch replacement question
Have you compared the part number of the door latch, before you removed/bought the SLK latch assembly? Although most if not all the DRIVETRAIN is identical, the body parts may or may not match. The part numbers are the only way to confirm this (look up the Chrysler part number then research if the MB part number is the same on the SLK part you got). Good luck!
I would do this BEFORE you tear into your crossfire door (or is it too late).
Old Jul 15, 2023 | 01:54 AM
svtmerc's Avatar
i haven't removed it yet no. but have a crossfire one also, but a piece is broken on it, i think its where the manual lock **** attaches. I can side by side compare them tomorrow
Old Jul 15, 2023 | 10:28 AM
dcskmail's Avatar
Left door latch asking $65, you can always make an offer ABC Auto Wrecking USA-AZ(Tucson) 520-294-1234
svtmerc
Dec 22, 2023 03:46 PM
HiFiBri
Aug 22, 2017 07:58 PM
2005 Ragtop
Jul 9, 2015 03:16 PM
6Speed Rdstr
Apr 28, 2008 11:15 AM
Maxwell
Feb 12, 2008 06:53 PM
