Replacement FOB
Old Jan 31, 2025 | 08:16 AM
ggr's Avatar
ggr
Default Replacement FOB
2005 Crossfire Base 6 sp 25k miles
Does anyone have a reliable source for FOB replacement/refurbishment. Tried a local locksmith to provide the fob and cut the key, then had tthe Chrysler dealership try to program it.
Car would start but shutdown right away. Also the lock and unlock buttons would not work.
Trying to find a reasonable cost source in the US.
Thanks,
Geo
New Member
Old Feb 24, 2025 | 08:56 PM
Default Re: Replacement FOB
Thanks,
Geo
New Member
Just saw your post.
Needswings.com Mercedes Swap Shop or look in the market place section under part or service. Some one does them there as well.
Old Feb 25, 2025 | 08:51 AM
ggr's Avatar
ggr
Thanks for the thread. Tried it but could not find a source for the FOB. If you have a source I would really appreciate your help. Have only one FOB and it is not reliable.
ggr
Old Feb 25, 2025 | 09:11 AM
dcskmail's Avatar
This is a key fob shell also available in black. https://www.lacartech.com/collection...KyMr3ynkRcS9Ug You will need the rfd chip from your old fob or the car will not start and the key shaft, how to video on youtube . Or you can buy a new key key for here : https://themercedesswapshop.com/?page_id=211
Old Feb 25, 2025 | 09:16 AM
Mercedes Swap shop can make you a complete spare key with electronics and new case.
Old Feb 25, 2025 | 10:11 AM
ggr's Avatar
ggr
Thanks, Tried to find the Swap Shop FOB provider but was not able to locate them. Do you have a specific address/location.
GGR
Welcome to the best car forum around! Sounds to me like you have a FOB that is either the wrong FOB or one that is missing the chip for the car that the car accepts. More information is needed... Did you buy this car with it running already? The FOB's electronics are not required to actually run the car, it only needs the right key and the chip IN the FOB to start/run the car successfully (given everything else is working properly). IF your car ran fine and you were able to drive the car before, AND you did not open the FOB for any reason, the issue may be the SKREEM or a few other related modules in the car. Come back and give more information as asked.
Old Feb 25, 2025 | 10:12 AM
Put "Mercedese Swap Shop" into your search engine.
Old Feb 25, 2025 | 06:11 PM
ggr's Avatar
ggr
Thank you for all your help, have shipped the original for rebuilt and getting a new back up. Hope things work this time. Wasted 300.00 locally.
Again thanks
ggr
Wes__Hutchinson
Mar 5, 2023 09:40 AM
rolly
Aug 13, 2013 11:33 AM
user 8202
57
Apr 9, 2013 10:28 PM
Mr Kilmouski
Dec 7, 2011 07:42 PM
neroco2
Jan 14, 2010 01:07 AM
