"mid" center console removal question
Old Mar 6, 2025 | 03:34 AM
nedj10's Avatar
Default "mid" center console removal question
I need to replace my mirror switch, I have the switch from ebay and per AllData's removal steps I should be able to open the center console "box" and pull back the lining to reveal two screws, however when I try to peel the lining back it feels rather glued. Is there something specific I need to do to get the "felt" lining peeled back?
thanks
Ned W
Old Mar 6, 2025 | 08:45 AM
Default Re: "mid" center console removal question
Go here and look under interior.
Old Mar 6, 2025 | 05:25 PM
red_2005_convertible's Avatar
No, the felt/carpet lining the console bottom has some tacky glue under it, but it should come up fairly easily. You pull it up from the back (the side closes the rear of the car). Only about 4" comes up. The console is wedged in there pretty tight, so after you get the front screws out, you need to slightly lift the back while lifting in the front - the front has plastic hooks connecting it to the middle console. You might also have a pneumatic line holding it down, but you should be able to maneuver the console to get access to the mirror control.
Buttercup Girl
Sep 2, 2017 08:31 AM
rvpilot
Apr 4, 2013 09:16 PM
DavidDennison
Dec 18, 2011 04:00 PM
blackroadster83
Apr 14, 2009 03:12 PM
blacklimitedcoupe
Jul 3, 2007 11:37 AM
