Dash cluster illumination hack.
Old May 30, 2025 | 10:11 AM
Romad's Avatar
Default Dash cluster illumination hack.
Looking for a hack to make my dash cluster illumination on whenever the key is on. My window tint makers viewing the instrument readings difficult to see. AND yes I do want the window tint to stay on the windows! Wondering if this could be done by jumping at the fuse block someway.. Has anyone else done this before? Guess I gotta fine a electrical schematic for tine instrument dash panel!
Old May 30, 2025 | 11:43 AM
bluecoupe's Avatar
Default Re: Dash cluster illumination hack.
Swap your illumination module for a DRL enabled one. You can get one from a canadian spec Crossfire.
Old May 30, 2025 | 12:56 PM
Romad's Avatar
Never heard of a DRL Module or where it's located. Guess I'll go "on the hunt" for one of those. In the. meantime I'll do a little research on DRL's. Thanks
Old May 30, 2025 | 01:22 PM
I believe that is supposed to be DTRL, Daytime enabled running light.
I just realized DRL would be the same. Daytime Running Light.
Old May 30, 2025 | 01:32 PM
Romad's Avatar
Yup, after a little research it's talked about in both ways. I don't really want daytime running lights though. "Seems" to me there should be a way to tape into the B+ of the ignition switch to the B+ of the dash illumination. BUT I'VE BEEN WRONG BEFORE, AT LEAST ONCE! LoL
Old May 30, 2025 | 04:00 PM
Maybe onehundred80 will chime in.
Old May 30, 2025 | 06:02 PM
onehundred80 has passed away.
Old May 31, 2025 | 09:56 AM
My bad, sorry !
Old Jun 1, 2025 | 08:24 AM
zip439's Avatar
You should read this linked thread before going too far with your instrument cluster lights. Not saying this will happen to you, but be aware of hacking into that light module. The feed is live all the time as are the seat adjustments. Get the wiring diagrams and proceed carefully: Fire Risk
Romad
Mar 20, 2021 02:09 PM
Ce_chief
Jul 18, 2018 09:03 AM
Toolman
Jan 12, 2018 11:49 AM
rodrofilo
Mar 24, 2016 01:54 AM
Montana Crossfire
Jun 10, 2009 11:27 AM
