No crank no start but the RCM isn’t at fault?
Old Sep 23, 2025 | 11:42 AM
Crossycurt's Avatar
Default No crank no start but the RCM isn’t at fault?
Hi fellow crossiers I had the good old no crank no start so I got a new RCM plugged it in and it fired straight up! Couldn’t be happier but after a few hours the dreaded no crank no start has happened again, I’ve bench tested the new RCM I got and all the relays are working as they should! So what else could this be? It’s got all the same symptoms where no start no crank and the radiator fan spins up really fast, if anyone could he please me out here I’d be much appreciated,
cheers.
Old Sep 24, 2025 | 07:10 AM
zip439's Avatar
Default Re: No crank no start but the RCM isn’t at fault?
Check the fuses on top the RCM and look closely at the contact connections: some have had trouble with those connectors.
PS How is the cars's battery? Does it show over 12.5 volts on a volt meter? Do the doors lock/unlock with the FOB? You can also try discounting the negative battery cable from the battery for a couple minutes and then reconnect. See if that changes anything.
Old Sep 24, 2025 | 07:08 PM
tighed1's Avatar
Check that two of the middle relays remain closed with the key in the ON position. If the Engine relay isn't closing, manually close the relay or wrap a rubber band around it to see if she starts.
If it does ya might wanta send the RCM to me to get it rebuilt.
Old Sep 25, 2025 | 07:52 AM
Crossycurt's Avatar
hello mate the battery’s brand new and reads as it should, you are correct about the fuses, I bought all new and replaced all of them and now it starts up every time, none of them had the little thin connected bit snapped but a few of them had some sort of soot where it looks like they’ve been burnt, thanks for the advice mate you’ve made me one happy chappy
Old Sep 25, 2025 | 09:56 AM
Thanks for the update and happy motoring!
Joliet John
Oct 6, 2025 07:12 AM
Sachin
May 20, 2023 12:13 PM
UnaidedPizza
30
Mar 5, 2023 10:14 PM
sama87
Apr 21, 2021 02:47 PM
AlexParra
Dec 29, 2016 06:17 PM
