Long term storage control module issues
Old May 11, 2026 | 02:45 PM
MrMoPar's Avatar
Default Long term storage control module issues
I have a 2004 Crossfire that has been stored inside on a lift for 7 years with no power to the electronics. I will be retrieving it later this year. Should I expect issues with the control modules once powered up again? Any advice/suggestions appreciated. I am already planning on purging fuel system, replacing fuel pump, filter, and injectors and fogging cylinders before attempting to start it.
Old May 12, 2026 | 08:12 AM
zip439's Avatar
Default Re: Long term storage control module issues
hock up positive battery cable first, Then turn on all the lights on high beam, turn A/C blower motor on and the radio; Tempering the jolt and voltage spike upon connecting the negative battery cable.
Might want to use compressed air to blow out all the fuse boxes and take the lid off the control box next to the battery and blow that out as well, before making the electric connection.
Good Luck!
oxoman
Mar 23, 2026 09:37 AM
pizzaguy
Jun 15, 2025 10:41 PM
Noel01
Mar 22, 2022 08:50 AM
STimms1
Jul 16, 2014 09:36 AM
