Heated Seats
Old Dec 18, 2007 | 08:25 AM
steevyn's Avatar
Question Heated Seats
04 Crossfire Coupe
Has anyone worked on their heated seats themselves? When I bought the car with 36k, the butt worked on the drivers but not the back. And the back worked but not the butt on the passengers seat. Now, nothing works on the drivers. I assume its the heating elements inside the seat, but I'm not sure about parts and tearing off the covers myself.
Thanks!
Steven T
Old Dec 18, 2007 | 08:44 AM
CoupeGirl's Avatar
Default Re: Heated Seats
Yhey say they are about 600 bucks each, I dont think i would try it
Old Dec 18, 2007 | 09:08 AM
spensley's Avatar
Somebody on here has put aftermarket heating elements in their seats - do a search.
Also...
Trouble shoot what's wrong. I had a similar problem with one of my seats - it was either a wiring loom or control unit that needed replacing - neither was that expensive.
Old Dec 18, 2007 | 03:57 PM
CrossfireLTD's Avatar
Cool Re: Heated Seats
Originally Posted by steevyn
04 Crossfire Coupe
Thanks!
Steven T
You will have to also replace the control unit, the control unit fails and then the elements burn out. If you are still under warranty take it back to the dealer. If you screw up the seat covers they are about $1400.00 per seat to replace.
Old Dec 18, 2007 | 10:58 PM
Afroman12345's Avatar
My two cents: Mine's an '04 with 22k miles and my drivers side went out entirely (sometime between cold seasons), thankfully still under warranty. Sounds like there's a lot of problems with them though. Too bad no recall.
Old Dec 19, 2007 | 03:41 AM
apkano's Avatar
Life is random...so am I.
I'm curious.......has anyone had their seats repaired only to have them fail again at a later date.
I'm wondering if this is going to be something that happens again and again?
Old Dec 19, 2007 | 10:45 AM
Electric Messiah's Avatar
I have not had this happen, but I'm expecting it. Since I got my bottom heaters repaired, they get very hot. Uncomfortably hot. From what I've read, this excessive heat is prelude to another burn out. So... I'm using them whenever possible to get them to burn out before warrenty expires.
Old Dec 19, 2007 | 10:51 AM
CoupeGirl's Avatar
Living in florida, I really dont have a need for them....lol
Old Dec 19, 2007 | 10:53 AM
Marc Levy's Avatar
My drivers seat went out right away at about 6k miles. It was replaced, now at 24k miles the back works, but not the bottom area. Passenger seat gets used nearly every day and has no problems.
Old Jan 30, 2008 | 10:48 AM
a12rag's Avatar
I changed the seats in my car, went for the Cedar color units ! Love that color combo . . . .however, I did notice that the bottom cushion on the drivers side does not heat up !! Decided to check on my original seats . . . took the ohm-meter out and measured at the connector - sure enough, on the drivers side, the seat back elements are ok, but the seat bottom was open circuit !!! I checked on the pass. side seat, and both were good ! These are the original seats that came with the car, and only have 12k km on the car (that's 7200 miles!!!) . . . not sure of the other seats, but only the drivers side seat bottom is gone. Should be relatively easy fix, but need to see the part first !!!
Seeing how I was up at my friendly dealership for some parts (oil filters for the Crossfire), I asked about a seat heat element repair kit . . . sure enough there is one listed. Have ordered it and will see how tough it will be to install . . . might have to let the dealership weanies replace it . . .but first want to see if I can !
Will post more, with pics once I get it figured out . . .
Cheers
Mark
A12rag
Old Jan 30, 2008 | 03:59 PM
theglot's Avatar
You will see lots of threads about seat heaters. Probably the weakest part on our cars. I took out the extended warranty just to get these covered. My car is in the shop now for the two bottom heaters.
Old Jan 30, 2008 | 04:56 PM
stlouistrucker's Avatar
Just curious if you are much heavier than your passenger.
Old Jan 30, 2008 | 05:04 PM
RMADERMAN's Avatar
Yep. Dealer had daughters seat out when I stopped to check if they were going to replace the roadster top. My heaters were repaired last year and set to be fixed this week.
Old Jan 30, 2008 | 05:09 PM
RMADERMAN's Avatar
You must have a hot...... Sorry couldn't resist the compliment! I am in Miami and every now and then I turn mine on. You are up in Gods country and it gets much colder up there then down here in paradise. where you can live your entire life and not speak a word of english.
Old Jan 30, 2008 | 06:25 PM
dhernand10's Avatar
Yes, I have had the seat heaters in the shop 4x for seat heater issues during the last year and a half, they just don't know what they are doing- my car is at the dealership right now as we speak it has been there for 5 days- The first and second time the dealership I took them to fixed the both passenger side and drivers side, only to have the drivers back side go back out within 1 week of the fix date- I have taken them to a new dealership and hope they get it right this time, my warranty is up in April, I have an extended contract but don't think they are covered under the plan I have- I thought about just letting them go because each time I think they are tearing the seats apart, but I hate that they just can't get them to work properly- at least I got a Charger as a rental-
Old Jan 31, 2008 | 02:40 PM
BRappaport's Avatar
Then you must move to a colder climate so you can appreciate those niece "Heated Seats" !! lol
Old Jan 31, 2008 | 03:49 PM
theglot's Avatar
Just picked up my xfire. 2 days in shop to fix seat heaters. guess what? they still don't work. I will call dealer tomorrow and give him the bad news.
Old Feb 1, 2008 | 12:00 PM
a12rag's Avatar
Hey everyone . . . I just picked up the Seat Repair Kit from my dealer. . . . I have attached a few pics, showing the part number and contents. . . . it has the instruction sheets included. When I get some more time I will scan and add these. Will let you know how it works out . . . .
Mark
A12Rag
PS - Interesting to read on the instruction sheet bottom corner :
K6855424 TP Instruction Sheet
Date : November 20, 2002
Would seem like this was an issue with the SLK that Merc. or Chry. did
not address when they built the XF !!!
Last edited by a12rag; Feb 2, 2008 at 09:22 AM. Reason: Adding Instruction Sheet Document
Old Feb 1, 2008 | 01:32 PM
Iamfink2's Avatar
Mark
A12Rag
Out of curiosity what did the kit cost and does 1 kit do 2 seats or only one?
Old Feb 1, 2008 | 02:00 PM
a12rag's Avatar
The kit is good for ONE seat - does both the bottom cushion and the back . . . . cost was $99.12 (Canadian) . . . this was "my" cost - my buddy is the parts manager at a local dealership. But I think it is probably less in the USA.
Mark
A12Rag
