oil filter question
Old Dec 19, 2008 | 07:13 PM
v8valiant's Avatar
Default oil filter question
ok i got my k&n filter and on the instruction note it shows two lines and the filter housing must go past the first line and come close to the second line, i cant seem to find any way to slip it on further, anyone run into this ? any ideas? thanks alot!
Old Dec 19, 2008 | 07:44 PM
Moparrbust's Avatar
Default Re: oil filter question
Did you put some oil on the new o-rings?
Old Dec 19, 2008 | 07:54 PM
007_MI6's Avatar
IDK, first thought in my mind, are you spinning it like the diagram shows? Just the first thing I noticed that might be the cause.
Old Dec 19, 2008 | 08:38 PM
v8valiant's Avatar
yes o rings are all lubed up and twisted and pushed till the filter statred flexing dont want to ruin the $20 filter, someone has got to know the trick. anyone? i looked and the original and the new k&n are the same height and diameter.
Old Dec 19, 2008 | 10:36 PM
Mimi05SRT6's Avatar
Once past the first line, it should have popped right in. As long as the first line is gone, then you are in good shape.
Old Dec 20, 2008 | 09:07 AM
v8valiant's Avatar
that is the problem it wont go past the first line
Old Dec 20, 2008 | 09:52 AM
70GT6's Avatar
Remove the filter, put a little oil on the inside lip of the filter. Also flip the over and try installing from the other side.
If you there is enough tension to bend the filter try pushing down without twisting.
Old Dec 20, 2008 | 05:16 PM
BlueStorm's Avatar
funny, that's what I say when the condoms don't fit anymore!!
Old Dec 25, 2008 | 05:55 AM
ThatGuy34's Avatar
it looks to me like you just need to get to the first line. jmho.
Old Dec 30, 2008 | 03:26 PM
DMS Xfire's Avatar
Pull the filter out and check and see if you left a rag or old filter o-ring inside housing. Then compare the new filter with the old one side by side.
deerhunter
Jan 16, 2021 10:56 AM
PNA
Nov 12, 2020 04:44 PM
xfireohio
Jul 20, 2020 12:03 AM
sittininthesun
Aug 24, 2015 10:47 AM
steps
Jul 27, 2015 03:14 PM
