Dead Cat at 3100 Miles?
Old Jan 29, 2009 | 08:36 PM
Mr. Max's Avatar
Cool Dead Cat at 3100 Miles?
Tried a new dealer today because my check engine light came on over the weekend. He said my cat was dead. I asked him how he knew my cat and informed him that she was alive when I left the house. Ok I'm being silly. According to him, the service manager, I have a bad catalytic converter. Financially this is a moot point because I'm still under the original warranty. I only have 3100 miles on the SRT. What do you think? Making work for themselves or bad part?
Old Jan 29, 2009 | 08:46 PM
SteveS's Avatar
Default Re: Dead Cat at 3100 Miles?
your light didn't go on for nothing ... I'd guess bad part ...
Old Jan 29, 2009 | 10:05 PM
Waynesworld's Avatar
If the cat is dead whats running on the wheel to run the car?? (Im Being funny)
If your cat is bad the power will be bad & the back pressure will be too much.
Try putting your hand by the exhaust to see how much flows out?
If they are willing to replace it, I would.
Good luck
Old Jan 29, 2009 | 10:28 PM
sowardcustoms's Avatar
mine rt one was replaced at 9500 miles
Old Jan 29, 2009 | 11:52 PM
Mr. Max's Avatar
Smile Re: Dead Cat at 3100 Miles?
Good luck
They gave me a loaner hamster,not as much torque, but better mileage.
They ordered the part. It appears they're on back order. As soon as it comes in I will get it replaced.
My car was a big hit over there. Everybody was oooing and awing.
I ran into another Crossfire owner and informed him about the forum and CICCI. I hope he logs on and joins.
We need more XF owners in L.A.
Old Jan 30, 2009 | 05:11 AM
cassidyrj1's Avatar
Now are they replacing both cats on one side or are they just going to replace one?
Old Jan 30, 2009 | 01:26 PM
Mr. Max's Avatar
Just one I believe. I hope no one gets goofy and claims my resonator delete caused the problem. So far no ones even mentioned it. I think even they would know that's B.S.
Old Jan 30, 2009 | 04:01 PM
bamp's Avatar
Had all CAT's replaced on mine @ 11500 miles, warranty runs out @ 12k so just made it in time
Old Jan 30, 2009 | 05:55 PM
Mr. Max's Avatar
You had a 12k warranty? What was it a Yugo? Explain please!
Old Jan 31, 2009 | 02:54 PM
BlueStorm's Avatar
you might want to have the car's AFR checked on a dyno, preferably before the cats, because these cars where detuned by Mercedes and run very lean, so you might need to get the ECU reflashed with the slk32 programming by a performance shop soon!!!!!!!!!!1
also NA cars are very lean runners and need larger injectors and a tune. MBZ probably used the C230 injectors on the NA 320. I know if I run it hard for 20 seconds in 5th gear the catalitic system gets real hot and gives off the tell tail rotten egg smell.
Old Jan 31, 2009 | 05:25 PM
Mr. Max's Avatar
Thanks BlueStorm, This is an SRT6 and I'm planning on a tune. I like this Austrian tuner because the re-tune comes with a remote so you can switch it back for smog checks and warranty work. It's kind of pricey though. What do you think about those two issues. I live in CA, and I don't know if the re-mapping would show up somehow either for the state or for the dealer.
I just noticed you're in CA too. If you have a tune how does it work with smog checks.
Old Feb 2, 2009 | 05:57 AM
bamp's Avatar
the cat is only covered by a 3yr/12000 miles (whichever comes first) warranty in UK
Old Feb 4, 2009 | 04:04 AM
whiskeyfrank's Avatar
bamp
My cars (UK car) cats were covered by the standard emissions 5yr 50K mile warranty look at my thread
https://www.crossfireforum.org/forum...ad.php?t=31515
just had mine replaced at 25K miles.
Ive been told they are a very weak part
waldig
Sep 2, 2015 11:02 AM
BrenLW
Aug 4, 2015 01:29 PM
Jul 29, 2015 06:13 PM
Jerrysrt6
Jul 24, 2015 09:15 PM
rmcdaniel12
Jul 21, 2015 11:35 PM
