Removing Rear Bar!!!
Old Apr 28, 2009 | 06:28 AM
kolevski's Avatar
Default Removing Rear Bar!!!
Anyone done it before?
I want to do it properly and not yank on it and brake all the clips!!
Old Apr 28, 2009 | 07:54 AM
tighed1's Avatar
Default Re: Removing Rear Bar!!!
I give.
What bar?
My car barely has room for a cup holder much less a bar!
Old Apr 28, 2009 | 08:14 AM
nate_man's Avatar
Originally Posted by tighed1
I give.
What bar?
LOL!! That was a good one!
Old Apr 28, 2009 | 08:30 AM
Montana Crossfire's Avatar
Yah, what Bar?
Oh I know what you mean but first to keep from breaking or bending the clips you need to go to the right side and move that one thing over about 1/8"!
Hope that helps.
Old Apr 28, 2009 | 12:23 PM
The secret is to give yourself more room, so I would suggest you remove the stools first.
Old Apr 28, 2009 | 12:32 PM
Squirrel Crusher's Avatar
I lost my bar once between the seats. Gosh I'm Soooo glad it was still in the wraper. Squirrel Crusher
Old Apr 28, 2009 | 12:44 PM
+fireamx's Avatar
I've heard of "passing the bar", but never removing it.
Old Apr 28, 2009 | 01:07 PM
tighed1's Avatar
I still don't know what he's talking about!
Old Apr 28, 2009 | 01:09 PM
Maybe the roll bar ???
Old Apr 28, 2009 | 01:33 PM
faiz23's Avatar
how about the bar in the rear the wall that separates the cabin from the trunk in the coupe. the top piece of plastic is that what you are talking about
Old Apr 28, 2009 | 02:56 PM
Someone asked once about removing the bulkhead entirely, is that what its about.
Lets see what its used for:
1, the umbrella holder and map pocket on the front face, not much rain in Australia and its only got a couple of roads through the bush, not needed.
2, the cargo cover on the rear face, every one is honest over there, not needed.
3, ? surely it must do something else ..........
Old Apr 28, 2009 | 05:12 PM
+fireamx's Avatar
I believe it's where they hid the gas tank.
Old Apr 28, 2009 | 11:38 PM
kolevski's Avatar
LMAO are you guys serious?
BUMPER BAR! what the hell do you guys call it? if you guys still dont know what im talking about I'll get a picture
Old Apr 28, 2009 | 11:50 PM
Peterk's Avatar
The gas tank is in the wall between the trunk and cabin?
Old Apr 29, 2009 | 01:43 AM
faiz23's Avatar
you mean the rear bumper lol
look up the stickey in the srt section they have the shop manual and the diagrams are in there
Old Apr 29, 2009 | 01:44 AM
faiz23's Avatar
gas tank is behind the hump in the trunk their is a thick piece of metal covering it. look at my gallery for pics when i added dynamat to the car.
the fuel pump is towards the driver side in the center of the car.
Old May 5, 2009 | 09:25 PM
NATTYY's Avatar
Champion!! thanks for that.
Old May 5, 2009 | 10:40 PM
Peterk's Avatar
So it's safe to drill into that wall between the trunk and seat if I want to mount amps, etc?
Old May 6, 2009 | 12:06 AM
faiz23's Avatar
depends where you are mounting it to but you gotta be careful and if i were you do not drill into the car instead slide a piece of plywood or MDF and then screw the amp to the wood.
if you are talking about the hump in the rear what i would do i remove the carpet and expose the metal and pull that metal cage off and mount a piece of wood and then screw the amp to the wood and install the metal cage back on.
Old May 6, 2009 | 12:59 AM
newCrossfire's Avatar
i think hes talking about the bumper reinforcement bar. which i wouldnt recommend removing because its a huge part of the safety of your vehicle. but i would imagine after removing the bumper its would just be a few bolts to remove it.
