intermittent no power when key turned
Old Apr 18, 2010 | 09:37 AM
stan37's Avatar
Default intermittent no power when key turned
I have a 2005 Roadster. In the past two weeks, I started getting a problem when starting the car. I turn the key, but nothing happens. All lights go on, radio plays fine, no warning lights. When this happens, the shift gets stuck in park. After a while the problem ceases and all seams OK. My dealer replaced the PCM (under warranty) saying it had "an internal failure" I drove out thinking all now was OK. After one day the car acted up again and was towed to dealer where it is now. ANY IDEAS AS TO MY PROBLEM???
Thanks
Old Apr 18, 2010 | 09:40 AM
Default Re: intermittent no power when key turned
I know this is basic, but are the battery terminals tight? I had this issue, and that's all it was.
Old Apr 18, 2010 | 10:12 AM
stan37's Avatar
Terminals were checked and are OK. In fact, when I turn key, I get full power to everything (lights, radio, all dash warning lights,) except to start car.
Old Apr 18, 2010 | 10:17 AM
to engage the starter, it has to have full power....how old is the battery, and did they check the connections at the starter...the only other area to look would be the ignition switch itself...good luck....but, the XF is very dependant on a good battery...voltage sensitive to all of it's sensors...if it isn't getting good power, the sensors cause strang things to happen. They can check voltage to different areas of the car...if they want to, but I would have them put a "load" on the battery to make sure it is at full strength. It doesn't take much to just light up gauges.
Old Apr 18, 2010 | 06:50 PM
maxcichon's Avatar
Relay Control Module? Tighead?
Try this?
https://www.crossfireforum.org/forum...-no-start.html
Old Oct 21, 2010 | 01:18 PM
ROBBSOUTHTEXAS's Avatar
If you can figure this out, please let me know. My crossfire has been stalling intermittently. When I turn the key nothing happens and the car is stuck in park. Usually starts after a few minutes.
PNA
Nov 12, 2020 04:44 PM
skeet370
May 15, 2018 12:57 PM
jgreen
106
Sep 18, 2017 11:46 PM
SparkieSRT6
Jan 11, 2016 10:49 PM
TOPLA
Jul 14, 2015 07:46 AM
