Cooling system pressurized or not?
Old Dec 15, 2010 | 10:29 PM
Question Cooling system pressurized or not?
...Deleted...
Old Dec 15, 2010 | 10:42 PM
magneticred's Avatar
Default Re: Cooling system pressurized or not?
From the service manual (page 7-19):
The cooling system normally operates at 97-110 kPa (14 -16 psi) pressure.
Old Dec 15, 2010 | 10:43 PM
In your other cars, you were trying to squeeze a liguid past your radiator pressure cap.Liquid is not compressible. Now you have an air pocket in the top of your pressurized resevoir allowing you to squeeze down the hose.
The cap is rated at 16psi +/- 2.
My gauge runs just below the half way mark. Hot days in traffic or on the Dragon, just above the half mark.
Old Dec 15, 2010 | 11:21 PM
...Deleted...
Old Dec 15, 2010 | 11:53 PM
dtinker's Avatar
Don't squeeze the hoses, as they get older you will crack the interior lining of the hose and cause it to fail. This brings up the chicken or the egg, did it fail because you squeezed it or ........
Dave
dtinker
Old Dec 15, 2010 | 11:59 PM
...Deleted...
Old Dec 16, 2010 | 12:03 AM
dtinker's Avatar
I've seen it happen, it makes a blister or bubble on the outside as the water gets in the crack. Admittedly, I always try to change mine before they are old enough to crack.
Dave
dtinker
Old Dec 16, 2010 | 12:05 AM
downwardspiral's Avatar
If there was air in the system you'd know it.. right away too. My theory is if you're not overheating your coooling system is working.
Old Dec 16, 2010 | 12:26 AM
Dave, been doing this for decades and have not cracked a hose yet. If they were that bad, I would have replaced em way before any test on a trip during fuelups! My XF hoses are fairly new so I wouldn't expect them to fail, but if any of them did Chrysler will come get it, fix it, and clean the mess (until July 2012 that is, HA!).
For the record 'x' psi will exert the same pressure on the hose if it's air or water. If it can move out of the way when you exert a greater pressure on it, it will. If it cannot move then you will increase its pressure even more and expand the hose to a greater extent.
Old Dec 16, 2010 | 08:07 AM
...Deleted...
awdspyder98
May 11, 2014 04:03 PM
onehundred80
Sep 13, 2012 09:27 PM
Crossfireone
Apr 16, 2009 07:06 AM
Steve Hellums
15
Jan 11, 2008 12:14 PM
lmf101
18
Dec 8, 2003 07:30 AM
