need help installing new a/c drier and expansion valve
Old Aug 13, 2011 | 04:59 PM
04alabaster04's Avatar
Default need help installing new a/c drier and expansion valve
can anyone tell me how to remove and replace the a/c drier and expansion valve?
Ive had some a/c problems and am trying to get them fixed before i sell off the car.
Any help is greatly appreciated. Ive already got the replacement parts, just not sure how to correctly do the swap.. Both parts are very hard to access
Old Aug 14, 2011 | 11:19 AM
Default Re: need help installing new a/c drier and expansion valve
I did some research and found this in the repair manual.. Also here is a link to the manual:
http://homepage.mac.com/gregmeach/XF...ir_24-HVAC.pdf
LIQUID LINE
REMOVAL OF RECEIVER/ DRIER
WARNING: REVIEW THE WARNINGS AND CAUTIONS IN
THE FRONT OF THIS SECTION BEFORE PERFORMING
THE FOLLOWING OPERATION.
1. Evacuate the A/C system. Refer to Page 24-116.
2. Raise and support the vehicle.
3. Remove the left front wheel and tire assembly.
4. Remove the front inner wheel well panel.
5. Remove the liquid line (1) from the receiver/ drier
INSTALLATION
2. Install the liquid line (1) to the receiver/dryer. Tighten to 17
N·m (12 ft. lbs.).
3. Install the front inner wheel well panel.
4. Install the left front wheel and tire assembly.
5. Charge the A/C system. Refer to Page 24-116
SUCTION LINE
REMOVAL OF EXPANSION VALVE
1. Disconnect the negative battery cable.
2. Recover the refrigerant from the refrigerant system. Refer
to Page 24-116.
3. Remove the retainer nut (1) from the expansion valve (3).
4. Slide the suction line off the stud and liquid line. Remove
the lines from the clip.
INSTALLATION
3. Slide the suction line and the liquid line over the expansion
valve stud. Tighten the nut (1) to 10 N·m (88 in. lbs.).
4. Connect the negative battery cable.
5. Evacuate the refrigerant system. Refer to Page 24-116.
6. Charge the refrigerant system. Refer to Page 24-116.
Old Aug 14, 2011 | 12:43 PM
waldig's Avatar
Talking Re: need help installing new a/c drier and expansion valve
How do you know that you need to replace the txv?? What are the symptoms and pressures?? Woody
Old Aug 14, 2011 | 07:07 PM
compressor clutch will not engage- very high pressure on the low side.
Im not positive that they need to be replaced.. however driers are know to go bad and the parts were only 20$ each so why not..
Old Aug 14, 2011 | 07:13 PM
How can you have high pressure on the low side if the clutch will not engage? When the system is not working, the high and low sides should equal out. That means the low side will be higher and high side will be lower than normal until the compressor kicks in. We need more info.
James
PS if the expansion valve is stuck closed, you will have too high pressure on the high side, and very low pressure on the low side, like a restriction.
Old Aug 14, 2011 | 07:28 PM
thats exactly why i think there is a clog somewhere.. The system was working and just went out on me out of nowhere while i was driving.
So my plan is to just replace these two parts, flush the lines, and see where it stands after that. If its not fixed by then, i will have it in to be checked out by a pro
Old Aug 14, 2011 | 07:34 PM
waldig's Avatar
Your low side pressure is high because the unit is not pumping, Try to energize the compressor and dont open the system until you know that it is going to assist you. Dumping the freon and evacuating the system is not cheap or easy to do. Woody
I suspect a problem with the controls.
Old Aug 14, 2011 | 07:42 PM
I don't think you read my post correctly. WE STILL NEED MORE INFO. Just throwing parts at a problem can be very costly and uneeded.
Old Aug 14, 2011 | 07:46 PM
waldig's Avatar
If the compressor clutch is not engaging, there is an electrical issue to be delt with. Woody
Old Aug 14, 2011 | 09:08 PM
arado's Avatar
If you replace the TXV and Drier you have to buy a $400 vacuum pump to remove air and moisture before recharge. Take the car to a pro. You can't do it. I spent 40 years doing it. Gary
Old Aug 15, 2011 | 02:02 PM
I know the system has to be vacuumed after it is opened up.. I do not have the pump to do so, so im bringing it to a pro to have flushed out, then vacuumed and recharged after i replace the parts
minimayhem
16
Aug 23, 2016 07:47 AM
MiamiTVR
Jan 30, 2016 02:15 PM
crmnal
Sep 6, 2015 08:07 AM
steps
Sep 3, 2015 07:24 PM
UNDER PSI
Aug 1, 2015 02:11 AM
