bas esp
Old Aug 15, 2011 | 11:21 AM
miknev's Avatar
Default bas esp
I changed the battery on my Crossfire Coupe and now the BAS ESP light is on any idea,s any one/
Old Aug 15, 2011 | 11:27 AM
maxcichon's Avatar
Default Re: bas esp
https://www.crossfireforum.org/forum...esp-light.html
Old Aug 15, 2011 | 11:32 AM
FUBU's Avatar
Default Re: bas esp
enough said But for the lazy non button pressers,.
drive for 5 min, turn the steering wheel. All should go away. ;D
Old Aug 15, 2011 | 09:32 PM
Default Re: bas esp
turn her to the left stop, turn her to right stop...drive her....
Old Aug 15, 2011 | 10:34 PM
Default Re: bas esp
I had my battery out of the car tonight. BAS/ESP light came on afterward. Never moved the car, started to turn to the wheel right and light went out immediately.
James
Old Aug 16, 2011 | 01:58 PM
killerkanadian's Avatar
Default Re: bas esp
Had the same thing happen to me when I was disconnecting and reconnecting my battery, but I assumed it was because I started it up while I was on jacks. Atleast its an easy problem to fix like they said.
Old Aug 17, 2011 | 12:50 PM
miknev's Avatar
Default Re: bas esp
Still having problems with the BAS-ESP I have tried resetting (turn steering wheel to left then to right ect) after i have completed the " fix" the light does go off--- but as soon as I depress the brake pedal the light comes back on.
Old Aug 17, 2011 | 01:04 PM
chisler29's Avatar
Default Re: bas esp
mine did the same thing, more than likely your brake lights don’t work either. it’s a switch that the brake pedal is against, until you depress the pedal. i was going to fix it, the part is pretty cheap....as far as crossfire parts go.....but im under warrantee so to the dealer it went. i can’t remember the name of the part, and my receipts are at the house. if no one chimes in on this i'll post the name of the part tonight when i get home and that should fix your problem.
Old Aug 17, 2011 | 07:32 PM
chisler29's Avatar
Default Re: bas esp
i checked the work order and it just said "brake lamp switch". its an easy fix, looked like the dealer charged $190 to do it. but since it was under warrentee i didnt worry about it.
Old May 13, 2012 | 07:41 PM
Thisguy574's Avatar
Default
All it is, is the brake pedal sensor behind ur pedal got pushed back. I just found Tht out today. I pulled it back out and shut my car off and my brake light and dash light All went away.
Old Feb 22, 2016 | 11:33 AM
4drturbo's Avatar
Default Re: bas esp
Brake fluid flush can fix it.
Old Mar 29, 2016 | 12:57 PM
kstewart's Avatar
Default Re: bas esp
I can't beleave it. I took the Crossfire for a test run today about 5 miles and the BAS/ESP light DID NOT come on. We will see down the road. We are leaving Thursday for North Carolina for the Crossfire tour. I feel better now but still not sure it fixed.
northwest_crossfire
May 30, 2016 05:19 PM
xfClifford
27
Nov 10, 2015 10:08 PM
Reliableron
Oct 17, 2015 10:19 PM
velociabstract
15
Sep 7, 2015 03:43 PM
Blackout317
Jul 7, 2015 08:38 PM
