ECU and SKREEM module
Old Jan 4, 2012 | 10:10 AM
britishcommando's Avatar
Default ECU and SKREEM module
Hello guys,
Finally look like im going to get my car repaired and back on the road.
BUT......
Just need a bit of info if possible.
I am buying a used ECU and SKREEM module for my 05 convertible and wanted to know if i needed to have parts numbers to give to the supplier or its just based on the year of the car?
£375 + VAT...is this good? 2 months warrenty.
Thansk in advance.
BC
Old Jan 5, 2012 | 05:35 AM
Default Re: ECU and SKREEM module
Please help!!
Old Jan 5, 2012 | 07:33 AM
maxcichon's Avatar
I'm sure the ECU is coded to the individual car/VIN and must be re-programmed to the new vehicle.
Maybe the same for the the security (SCREEM) module. A dealer-only operation?
Old Jan 5, 2012 | 06:41 PM
Thanks mate, thats what i need to find out for sure before i go and part with the cash. As long as a 05 plate ECU and Skreem can be reprogrammed for mine then i can go ahead.
Does anyone know this for certain?
p.s i did try and call Chrysler today.
Thanks,
BC
Old Jan 6, 2012 | 07:18 PM
Spoke to Chyrsler today and they said that it isnt possible to reprogram a 2nd hand SKREEM or ECU.
Please could someone confirm this?
Thanks
BC
Old Jan 6, 2012 | 07:46 PM
bluecoupe's Avatar
ECU can be reprogrammed, don't know about skreem
Old Jan 6, 2012 | 09:24 PM
mferreira3417's Avatar
skreem will read vin from ecu and if not correct vin will shut down ecu i think you can leave the key in the on position for a certain amont of time and it will clear vin but must use battery charger when doing so i think its like 3 hours but vin must be programmed into ecu but it has to be cleared first and dealer can enter new vin there is a company that you send ecu to and they can clear it maybe eurocharge can do it, worth a call
Old Jan 7, 2012 | 04:26 AM
Thanks guys.
I really want to try and cover all angles because the total for these bits of kit from the dealers and no labour is around £2000!!! Ouch.
ANy other help or advice is appreciated.
Thanks
BC
REYMARTZ
22
Aug 7, 2021 12:37 PM
minimayhem
17
Jan 19, 2016 02:10 PM
RacerXofFL
Sep 15, 2015 05:00 PM
sk8erjosh09
Sep 4, 2015 09:24 PM
da pink
Aug 12, 2015 05:20 PM
