How to: Install dual USB charger
Old Jan 13, 2013 | 11:22 AM
Bill F's Avatar
Default Re: How to: Install dual USB charger
Lol, this is getting silly. Maybe someone should start a thread titled "solution's to avoid installing a semi-permanent USB adapter"?
By the way, I have one of those USB cigarette lighter adapters beside me right now. This is my own fault, as I wan't more specific as to why I installed it. I've revised the thread now, so everyone isn't piling on with alternate solutions.
To late the damage is already done. No need for a new thread when there is an exchange of ideas to resolve an issue which took effort on your part concerning a usb port for your car. When you build it they will come, with ideas on how to do it better or easier and cheaper. Nice work though.
Old Jul 10, 2020 | 08:46 AM
208james@gmail.com's Avatar
Hi. Has anyone installed a USB outlet in the trunk inorder to charge devices out of site. I was hoping to find an ignition switched power supply either in the trunk or behind the seats to avoid running a wire from the cigarette lighter or glove box light. Thanks
Old Jul 10, 2020 | 02:44 PM
There are battery feeds, several of them, to the central locking pump (all cars), which is in the passenger wheel well (convertibles) or under the floor mat (coupes).
There are also two battery feeds to the power top module (convertibles) in the driver's side rear wheel well.
I know of no ignition switched power in the back of the car.
I've never owned a coupe. Getting to these battery feeds is SIMPLE in a convertible (you just raise the lid and the wiring harnesses are exposed), but I have no idea how to remove the trim of a coupe.
If you want to play around with this, you should download the service manual from our tech area. If you really want ignition switch power (WHY?) it is a simple matter (again, in convertibles) to run a line to the back from the underhood fuse box on the driver's side.
Old Jul 10, 2020 | 03:13 PM
Switched and un-switched power is available on the radio connector.
Red and yellow wires, forgot which is which though.
Old Jul 10, 2020 | 03:26 PM
Just remember if you use a battery feed (hot all the time), you run the risk of leaving something plugged-in/energized and killing the battery (if left on). Just saying!
Old Jul 12, 2020 | 03:59 PM
Thanks for the replies In the end I decided to run a line from the battery with a piggyback fuse which gives me a separate fuse to the device and the ability to easily change from lgnition switched to unstitched by just moving the piggyback fuse location in the fuse box. Thanks again
55chevy
Jul 22, 2024 02:31 PM
Jonacross
20
Jul 17, 2017 11:19 PM
Ralph289
Sep 21, 2015 09:34 PM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
bbsrt6
Sep 19, 2015 11:21 AM
