water pump torque spec
Old Sep 1, 2013 | 08:44 PM
mastermikie's Avatar
Default water pump torque spec
Ok atm the sites ability to download the documentation is nil. i was hoping to find the service manual for all the correct info on replacing the water pump. at this point i can find enough general data(and have done water pumps on other vehicles) that i think i can do this easy enough. my only concern is re-torque on reassembly. anyone have the torque spec for the water pump bolts?
I say thank you in advance.
Old Sep 1, 2013 | 08:57 PM
Default Re: water pump torque spec
See attached details.
Old Sep 1, 2013 | 09:02 PM
TYVM.. you rock!
Old Sep 1, 2013 | 09:20 PM
grip grip's Avatar
That diagram is very misleading. If you try to put 26 ft lbs on the smaller bolts they are going to break. Please take a look at the attached specs also from the service manual.
M6 bolts: 7 ft lbs
M8 bolts: 26 ft lbs
Old Sep 1, 2013 | 09:31 PM
TY for the correction.
always appreciate info that prevents breakage.
Old Sep 1, 2013 | 11:00 PM
Sorry about that. I just got it from the manual. but when grip grip piped up I remembered his post a few months back.
Just shows you cannot believe all you see, two bolt sizes. I should have looked up that other page.
Old Sep 1, 2013 | 11:49 PM
Default
Its all good. I appreciate the efforts of all.
Old Sep 2, 2013 | 12:30 AM
grip grip's Avatar
You're rarely off your game, so definitely an anomaly.
Old Sep 2, 2013 | 07:26 AM
waldig's Avatar
Talking Re: water pump torque spec
Torque is king on this work and it is really important that the bolts be kept straight as there are MANY and several different lengths to keep track of, Woody. Enjoy.
Old Sep 2, 2013 | 01:09 PM
I am just thankful for such a good resource. i spent quite a bit of time reading all the threads on water pump replacement. lots of good info!
Old Jan 5, 2014 | 05:21 PM
mikehagg123's Avatar
Should anti seize or anything else be put on these bolts when installing the water pump back in? Only on one post do I remember someone mentioning anti seize.... I'm probably going to use it because "why not"....but just thought I would check to see if anyone would recommend for or against it. Thanks.
Old Apr 30, 2017 | 10:19 AM
Chrisjlyon's Avatar
M6 bolts: 7 ft lbs
M8 bolts: 26 ft lbs
Damn wish I had searched for this thread two days ago. I was mislead by the service manual torque and ended up snapping two bolts installing my new pump. Oh I could get out but the other no luck. It's basically ruined that boot hole.
Old Apr 30, 2017 | 06:12 PM
I think that the torque value for the 8mm bolt is too high, it would be OK for a 10mm bolt in aluminum. I think the value for the 8mm bolt should be about 16 - 18 Ft.Lbs. I studied various charts and came up with those figures. I do not think the class of the bolt should alter the torque value in our aluminum block.
You were lucky the 6mm bolt broke instead of stripping the aluminum thread.
In matters like this I think caution should be used.
Old Apr 30, 2017 | 06:18 PM
Chrisjlyon's Avatar
No, turns out I did that too. Guess I'll have to tap it and put a helicoil insert in. Fml.
Old Apr 30, 2017 | 07:11 PM
Attached are a couple of resources I've used for tightening torques of metric fasteners.
Old Apr 30, 2017 | 08:11 PM
We need the specific torque figures for aluminum, figures given in charts are most often the recommended torque for that particular screw in high strength materials, the figure is adjusted downward for softer and more ductile materials.
Old May 1, 2017 | 04:20 PM
See if this chart gives us what we're looking for.
Old May 7, 2017 | 06:43 PM
Chrisjlyon's Avatar
Well got it done. Spent the day today drilling and tapping. Ran it and went for a little drive. No leaks so far.
blackpepper
Oct 4, 2017 06:09 AM
Billy22Bob
Sep 28, 2015 08:08 PM
Sep 26, 2015 10:21 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Selbyl
Sep 26, 2015 04:15 AM
