Oil change
Old Mar 23, 2016 | 03:07 PM
Fildo Dog's Avatar
Thumbs up Oil change
Folks:
Much confusion despite some great posts on an OIL CHANGE for a Crossfire.
Here in very clear terms and photos is the whole process broken down.
https://howtune.com/articles/93-chan...sler-crossfire
Hope this helps.
Regards,
Fildo Dog
Old Sep 16, 2022 | 11:17 PM
abergero's Avatar
Default Re: Oil change
Doing my first oil change on Saturday - thanks for sharing that detailed instructions and torque settings. Great instructions and pictures,,!
Old Sep 17, 2022 | 01:25 PM
The ONLY thing I see WRONG (IMHO) is you will not need 9 quarts of oil. Use 8 quarts (you'll NEVER get all the old oil out) and run it for a day or two. THEN check the oil on a LEVEL surface (side-to-side & front-to-back). Sometimes, even 8 quarts is too much (if you didn't get the old oil out 8 quarts worth). You do not want to overfill the oil. One reason, there have been quite a few cases where the oil level indicator in the crankcase 'jammed' due to a high oil level. IF at a day or two timeframe AND your quite sure you want the oil level at the topmost place on the dipstick, you can add a little at a time until it is where you want it. Another tip, I use the topsider, it is a tool to vacuum the oil out from the dipstick tube. This way you don't have to jack the car and you'll not have to replace a lost part or damage your crankcase oil plug. Good luck (really, it is EASY!
70GT6
Jul 24, 2010 01:39 PM
chuck65
Aug 26, 2008 12:59 PM
waldig
Jun 5, 2008 06:35 PM
Rickyms
Sep 19, 2006 01:36 PM
cfire
Nov 5, 2005 12:22 PM
