Programming Garage door opener
Old Jan 14, 2019 | 06:34 PM
04guy's Avatar
Default Re: Programming Garage door opener
Found it but now what? I
Old Jan 14, 2019 | 06:40 PM
04guy's Avatar
This doesn’t look as though it is set up to disable the tpms/garage door opener... why is it still not getting power? Is this supposed to be plugged into something or is it the end of the circuit? Is there a fuse for this?
Old Jan 14, 2019 | 06:51 PM
If you go to “Headliner Removal and Recovering” in the Interior section of my “Index of Crossfire ..... “ in my signature below you will see the Garage Door Opener module and the connector that goes to it. I am in Canada with two Chamberlains and I followed these instructions.
Here is the link. CLICK
Here is the garage door opener.
Old Jan 14, 2019 | 11:08 PM
zip439's Avatar
04guy, did you read post # 4? Maybe your in the same boat.
Old Jan 16, 2019 | 09:03 PM
CROSSFIRERUSH's Avatar
Originally Posted by venture2408
I just bought a new Chamberlain garage door opener (model c455 in Canada). Tried all the posted programming procedures but could not get the Homelink in my 2005 Crossfire to work with it. Turns out I had to buy the "Liftmaster 855lm Homelink Repeater Kit" to get it to work with the Security+2.0 technology of the door opener. Bought the repeater kit from Amazon and everything works great now.
I'll 2nd the above. Had the same issue and installed this...voila! She works like a charm. Googling this shows a number of sellers. Cheap give or take $20.
https://www.google.com/search?q=lift...hrome&ie=UTF-8
Regards,
