Key
Old Mar 30, 2022 | 11:02 AM
triplmmm's Avatar
Default Key
Keys( both) won't open locks remotely. Car drives fine. Changed batteries. Any suggestions??
thanks
Old Mar 30, 2022 | 06:47 PM
Default Re: Key
thanks
Have you tried to synchronize the FOB's to the car yet? The procedure is in the owners manual. This sometimes happens when the batteries are left out of the FOB's too long or they die and you don't replace them before the memory is lost. I am hoping you placed the batteries in the FOB's in the right order? Good luck.
Old Mar 30, 2022 | 08:45 PM
triplmmm's Avatar
Default Re: Key
✓ & ✓ I'm not overly concerned as long as the car still operates. I rarely drive it.
Old Mar 31, 2022 | 09:38 AM
NeedsWings's Avatar
Default Re: Key
does the lock/unlock button on the dashboard function?
Old Mar 31, 2022 | 11:32 AM
triplmmm's Avatar
Default Re: Key
No. Any advice appreciated..
Old Mar 31, 2022 | 11:41 AM
NeedsWings's Avatar
Default Re: Key
you most likely have a water leak letting water get to the central locking pump in your trunk, pull out the trunk carpet on the passenger side, remove the foam insert and checkout the pump/connections for water evidence.
Old Mar 31, 2022 | 12:47 PM
Default Re: Key
I second that comment by NeedsWings about checking out the right side 'trunk' under the foam inserts. If you have it (damage) there you'll not be driving it much longer, as a lot of 'stuff' that makes the car go runs through and is affected by that module. Good luck.
Old Mar 31, 2022 | 02:06 PM
Default Re: Key
Roadster or Coupe?
DirtyDen8810
Oct 5, 2019 08:29 PM
arado
Jun 13, 2010 07:49 PM
supercrossfire
Oct 2, 2009 10:23 AM
DICKBEE7631
Dec 14, 2007 07:58 AM
