Creaky Exhaust?
Old Aug 19, 2022 | 08:08 PM
Uriah's Avatar
Default Creaky Exhaust?
Hi there!
New to this forum after following for the past 3/4 years. I have a 2006 RHD (UK) Crossfire Roadster and it has suddenly started making a fairly loud constant creaking noise, which I originally assessed as possibly being a broken coil spring or a dry ball joint, However, it seems to be being emmited from the exhaust system. There is no obvious blowing and as far as I can tell it's soundly supported. I'm after any thoughts on whether this has been witnessed by anyone else and where I might start looking please...
Old Aug 19, 2022 | 10:44 PM
Mommasride's Avatar
Default Re: Creaky Exhaust?
Welcome sir
Jack her up and have a good look see, inspect, move the wheels around, torn boots, breaks, bent rods, it should all be tight n clean. Thats where I start. Report your findings, good luck.
Old Aug 19, 2022 | 11:01 PM
Have u checked the driveshaft center bearing support,, some times when car is jacked up u check it and say it's good.
I did that then i stopped the car pushed down the brake ,,pushed down the gas peddle and took off hard , the creaking noise
changed to a heavy thump, thump, thump very loud, i knew that it was the center bearing jim
Old Aug 20, 2022 | 11:41 AM
I had a pair of 'dry' front stabilizer bar bushings that every time the car leaned or rolled over a transition in the road, creaked BADLY. After finding the culprit, installed a pair of 'moog' bushings and what a difference! It then actually made other noises I couldn't hear, hear-able. It was a win though! Good luck finding your creak'in creak!
Old Aug 20, 2022 | 05:48 PM
Uriah's Avatar
Thanks to all for your responces. It's great that it's an active forum, despite the car being out of production for many years. I'm guessing that it's because it's such a unique and enjoyable car! Certainly unique in the UK, where they are as rare as hen's teeth!
I'm now in a dilemna of whether I take a look myself (never having had her up on ramps) or go back to the garage that I tasked with fixing her. I'll try the later option first, as they owe me one - after having told me that everything is fine! If not, it's off to work with the pry bars - which is something I don't do much of these days!
Thanks again.
THETESTER
U.K.
21
Oct 12, 2018 12:30 PM
Dharma1
May 8, 2014 09:28 PM
essex.dave
Sep 4, 2011 10:18 AM
j-fire
Feb 19, 2009 10:38 AM
getshawty
Europe
Oct 1, 2008 09:39 AM
