Telescopic steering wheel problems
Old Jan 23, 2024 | 01:40 PM
chirimoya's Avatar
Default Telescopic steering wheel problems
Hi, I have a 2006 Crossfire.
The telescopic steering column mechanism is not working properly so sometimes my steering wheel gets pulled back while driving manoeuvres and obviously I can’t adjust it father or closer.
If somebody has had the same problem and solved it I would appreciate you sharing the solution .
Or if you know the name for the part I should look for to change.
Best,
Christian
Old Jan 23, 2024 | 01:48 PM
Default Re: Telescopic steering wheel problems
Have you locked it in place?
Old Jan 23, 2024 | 02:16 PM
chirimoya's Avatar
Yes, but it unlocks
Old Jan 23, 2024 | 04:01 PM
Originally Posted by chirimoya
Yes, but it unlocks
Sorry I cannot help as like most others I have steered clear of this problem.
Seriously it is the first time I have seen this problem arise, have you studied the Service Manual or looked closely under the steering column to see how it works?
Old Jan 23, 2024 | 10:32 PM
Best,
Christian
I'v'e been here since 2009 and never heard this one. But it's a mechanical assembly, no Mercedes specialist is likely needed, just someone who is good with mechanical fixes.
That section of the service manual is even more worthless than the rest of the joke of a service manual we are stuck with.
You or someone has to just get in there and find out what is loose/broken.
Old Jan 24, 2024 | 04:25 PM
bc75's Avatar
Mine was broken when i bought it. I wedged a small piece of metal in it.
Old Feb 18, 2026 | 07:59 AM
Dasfarrar's Avatar
Old post. But funny.
mine just did this too..
haven’t looked into it yet as it just happened.
F4celess
Aug 2, 2022 04:42 AM
phil alvirez
Feb 16, 2022 03:19 PM
princepenson
Jul 29, 2015 07:44 AM
kjmurphy
Jan 15, 2008 10:03 AM
Crisis
Nov 7, 2006 09:27 PM
