swap your diff in one hour.
Old Mar 6, 2026 | 11:16 PM
Default swap your diff in one hour.
Update on changing the rear end ,(differential)
1 remove the drive shaft (at least the rear 1/2 remember to align the notches when reinstall)
2 install a jack under the rear end ( diff)
3 remove the three bolts that hold the diff.
4 lower and nose dive the diff to the left or right, (hard/push it ) this will let u get the axles out
You may loose a little oil, so have 2 qts ready to replace the oil
5 lower your jack / diff it is out,,
6 now reverse that to install diff back into the car
note ::You do not have to remove any control arms you don't have have your car realigned simple job about 1 to 1.5 hours.
Old Mar 7, 2026 | 01:04 AM
UrbanE's Avatar
Default Re: swap your diff in one hour.
Always great information.
When removing axels, any issues with the axel seals?
Old Mar 7, 2026 | 10:43 AM
No, but you will have to force out the last inch
of the axle coming out of the rear you will think it won't come out, just push the diff a little more down
and away from the axle U R removing (nose dive the diff )
I have changed 4 or 5 that way , and now it is like why did i ever take all the control arms off ,,
I remember the first or second time we were swapping the diff, i took off the tires, most of the brakes all the control
except the lower control arm the brake plate folded down after we removed the nut and took the axle out
,yes removed the springs also I was going by the book .
after i think the third or 4 time , we were taking apart just one side ,Miami ,Matt ( matt said hold on let me see how low
this rear will go before it binds,, As he lowered and doing a nose dive and forward and the axle came right out .
i mean we went Oh sh** we did it . Just work with it ,it will come out We did the other side like wow The diff is out.
for the other side just move the diff away from the axle and of course it comes out like butter.
now reverse that and back in with the new or other one.
Thanks for that question. it required an answer about how we got it out that some may stop there and start removing control arms, jim
Old Mar 8, 2026 | 01:18 AM
UrbanE's Avatar
Wow
hands on experience is everything
thank you
Old Mar 18, 2026 | 01:41 PM
more pictures --click the link below sorry i am not very good at taking pictures.
https://share.icloud.com/photos/05fB...hkVK7Fx0_Nui-A
Old Mar 19, 2026 | 08:50 PM
Thanks Jim!
amx1397
15
Mar 6, 2026 11:10 PM
slyfox1812
Sep 16, 2023 09:03 PM
amx1397
Jun 15, 2022 10:57 PM
gblack32
May 13, 2017 08:32 AM
amx1397
Feb 21, 2016 11:59 AM
