2005 Crossfire - Hatch Jammed Shut
Old May 4, 2026 | 07:39 AM
Shmuller's Avatar
Default 2005 Crossfire - Hatch Jammed Shut
Hi. All of a sudden, I can't open the back hatch. I hear the vacuum system trying to disengage the locking mechanism but does not. The handle is engaged. I've tried the unlock on the fob 5 times quickly to no avail. I may have to re-sync the fob.
Thanks!
Old May 4, 2026 | 08:53 AM
Default re: 2005 Crossfire - Hatch Jammed Shut
Roadster or coupe?
Old May 4, 2026 | 08:56 AM
Shmuller's Avatar
Originally Posted by ZERACER
Roadster or coupe?
Sorry.. My Bad. It's a coupe. I'm new. Any way to put more Crossfire specifics with my info? Thanks.
Old May 4, 2026 | 09:37 AM
Try opening it from the inside. There should have been a way to enter your signature when you signed up?
Old May 4, 2026 | 09:43 AM
Shmuller's Avatar
So if I understand correctly, climb my old butt into the back. Is there a mechanical release cable? Is there a video here somewhere? Sorry and thanks!
Old May 4, 2026 | 10:23 AM
Only the lock, unlock button on the dash.
Old May 4, 2026 | 12:37 PM
exparamedic's Avatar
I have never had this problem but there are a couple of links here. Most for roadsters though.
Have you checked to ensure the air line to the lock is intact?
Check out this one in the link below.
https://www.crossfireforum.org/forum...744d1517804340
Hope this helps. There is also a video that had the same problem.
Of course another roadster. There was a whole series on that car in the UK.
If I remember right it had a plate blocking access that was only in Europe.
I could be wrong.
Jim
Old May 4, 2026 | 12:48 PM
Also check this thread.
Jim
https://www.crossfireforum.org/forum...tml#post392156
Old May 4, 2026 | 08:23 PM
First try pulling fuse 26 in the engine box, then replace it with a new fuse.
If that doesn't work here is a quote from the thread exparamedic posted:
"Okay this is how it is done my Padawans-
remove rear plastic lower panel there will be 1 screw that needs to be removed, that is located where the rear hatch handle is-
slowly pull off the panel , it has 6 clips to hold in place - but comes off nice-
There is a small open area on the Left hand side of the latch (Upper Left)
press down with a flat head screw driver-
you will feel the trunk release and that's it-
However i am still unable to get the device to completely unlock, so when i shut my trunk again it locks, but i was able to get it to open
If your slim you should fit fine, If your a Big Guy you might sweat a little."
I took the leisure of correcting his spelling and punctuation. LOL
Old May 4, 2026 | 08:50 PM
Shmuller's Avatar
Awesome. Thanks so much!
pizzaguy
Sep 27, 2024 10:59 AM
Kalle
Jul 3, 2022 04:04 AM
Jorga
Dec 20, 2018 09:05 PM
dennisoates
Oct 16, 2016 09:35 PM
chrisificti0n
Mar 7, 2015 02:42 AM
