Convoy On Route to Marlow
woody and me are meeting up (as usual) for the drive down to Marlow and meeting up at Watford Gap services M1 at 10.00 on Sunday. Then we can then call in at Cherwell Valley services M40 at 10.50 - 11.00 - I know ZeroZero is coming down M40 from Coventry and Mogsta from W.Mids - let us know if you will be there, plus anyone else whos around!
Steve
Steve
Hi,
just returned from hols and catching up. I am 50/50 chance of being there at the moment and if I go will probably meet up at Cherwell.
Depending on how late it is that I decide will probably call you ( Steve ) to confirm.
cheers,
Paul
cheers,
Paul
Originally Posted by beeblebrox
Hi,
cheers,
Paul
cheers,
Paul
Cheers for now!
Steve
Originally Posted by The bodyman
I should be there just before 12:00. I will try to save some spaces.
Jon
Jon
I had decided to go, but just had a brake problem, just started off, pedal went to floor without much affect once and now has grinding noise when braking on near side front, but brake pedal functioning OK and braking effectively. After returning to home grinding noise seems less, but still there.
Can't see anything easily and noise has reduced. Can't tell if it just grit ( had jet washed wheels before hand, could that blow grit in ? ) or if there is a more serious brake problem.
Will take a look in the morning and decide.
Paul
Paul
04Fire
Sep 15, 2015 07:40 PM
