Audio Problem Cured...
I had reason to remove the radio, and on replacing had no station reception..CD worked..radio was serching for stations...I removed again and checked wiring contactions, aerial both ends etc.
Replaced, still the same problen....I felt it had to be the aerial not receiving a signel...I was correct. Fault, on very close inspection of both the aerial cable end and connector on rear of radio, I found the fault, the male conector is very thin almost pin size and was not conecting firmly with the radio plug..on closing the receving connector, squizing together, the problem was fixed..
Thought the above info may be usful to xfire owners at some stage
UKKen.
ing NOW..
UKKen.
ken i think we are going to have to appoint you our technical guru with all these little problems you keep solving
...see you at end of the month
Interesting! My radio has started changing channel by itself in the last couple of weeks (she seems to favour radio 4 and city talk...) I wondered if some moisture had got in somewhere but perhaps it is a similar problem?
Jon
Is it set on Auto Scan? Try manually setting the stations and see if it holds them
Or may be as she is a female roadster, she just keeps changing her mind!
tcar32909
Aug 1, 2024 02:41 PM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
cdcrone123
Sep 20, 2015 10:02 PM
skeet370
29
Sep 18, 2015 05:53 AM
