bulb out warning light
Old Jul 19, 2011 | 08:44 PM
Flyingv's Avatar
Question bulb out warning light
hi all........I have a bulb out warning light come on now and again, but have no lights out any ideas
cheers
Old Jul 19, 2011 | 08:51 PM
RMADERMAN's Avatar
Default Re: bulb out warning light
cheers
Check the licence plate lights.
Old Jul 19, 2011 | 08:55 PM
Flyingv's Avatar
Thumbs up Re: bulb out warning light
hey yeah thanks I will have a look thanks
Old Jul 19, 2011 | 10:18 PM
Broken filament in a bulb? If the bulb burns out soon you'll know which one.
If the filament is just sitting in place and making contact there is no problem, when it does not make contact the idiot light comes on.
Old Jul 20, 2011 | 06:39 AM
Flyingv's Avatar
thanks for that
Old Jul 20, 2011 | 06:55 AM
autumnmass's Avatar
Had the same problem, however mine was eventually the driver's side brake light.
Old Jul 20, 2011 | 07:33 AM
I made my comment on the assumption that all bulbs appeared to work as he said.
According to the manual if a brake light goes out while driving the light will come on when the brakes are applied and stay on until the ignition is switched off.
I have only had a headlight go out so I have had no experience with the brake lights.
Old Jul 20, 2011 | 05:24 PM
By sheer coincidence my bulb out light came on today, opened the door to look for the bulb and it went out.
Started the car and it came on and went out again, came on and went out. WTF.
Guess I'll find out soon.
I cannot complain because with day time running lights the lights get used all the time.
Old Jul 20, 2011 | 08:42 PM
Flyingv's Avatar
mines been ok today...I'm new to crossifire's but love it so far...do they have double reverse lights..I did notice when I backing up by a shop window one was out if there are 2 could that be it??
Old Jul 20, 2011 | 10:02 PM
There are two reverse lights.
Old Jul 24, 2011 | 03:10 AM
11 FEB's Avatar
Not on UK cars!! nearside is reversing light, offside is foglight.
Old May 28, 2012 | 12:41 AM
aallman72's Avatar
Thanks for the license plate tip. That warning lights been bothering me for months.
Old May 29, 2012 | 11:14 AM
*AL*'s Avatar
Yep only 1 reverse light and fog here in the UK.
Old May 29, 2012 | 12:17 PM
aallman72's Avatar
Spoke too soon, indicator came back on, so its not the license plate light.
After doing the sticky ignition fix I didn't snap in the High beam connector all the way. Went back in and secured that, but now I have an intermittent instrument cluster illumination lamp. Must have jerked something loose last time I was in there. Still not sure that will fix it the bulb out indicator.
Old Jun 2, 2012 | 10:21 PM
monkman's Avatar
I had the very same problem...for the life of me I could not locate the bulb as every single light on the car worked. When i took my car in for an MOT the guy told me he replaced a 'brake' light bulb because he saw the warning light on. The reason why all the lights were working was that the brake light bulb filement was broken but still making contact with the prongs inside the bulb..but any judder and it would lose contact. I checked all the bulbs but not close enough. If this happens again in future I know what to look for. Just pull the brake light bulbs and check them out very carefully as I am pretty sure that's your problem.
Old Jun 10, 2012 | 07:18 PM
aallman72's Avatar
It was the brake light, guess I just didn't check it close enough.
Old Jun 12, 2012 | 05:11 AM
11 FEB's Avatar
Just something to throw into the mix, If you replace standard bulbs with LED ones, this can cause the buldout light to come on.
also, don't know if interior lights are on the system but might be worth checking the one in the boot.
Old Nov 6, 2020 | 11:50 PM
315143's Avatar
Talking Re: bulb out warning light
cheers
Check the rear fog light globe (right hand rear)
Old Nov 7, 2020 | 11:40 AM
Welcome to the forum.
It's been nine years... always check the DATE of the post before you reply!
Old Nov 8, 2020 | 01:13 AM
315143's Avatar
Date is irrelevant to someone with the same problem, like my neighbour yesterday!
