One for you technical guys
Old Aug 30, 2011 | 11:45 AM
11 FEB's Avatar
Default One for you technical guys
2005 SRT6,
Problem, sometimes when accelerating there is no power at all, this does not relate to any speed or any revs but seems to happen mostly when cruising at approx 60/70mph put my foot down and nothing!! (the gearbox does kick down) but it also can happen just pulling away off a roundabout but it never does it from a standing start.
The error codes that come up are,
P2027 [ 1,60, 7,89 ] -152 please refer to relevant technical manual
P2027 Y31/1 (EGR -0 vacuum transducer ) (po 403)
P2004 -0 The load Limit is active (P1999)
I at first thought the problem was with the mapping so took the car to a mapping "expert" this is where the above info came from. I lost confidence in them half way through the diagnostics and pulled my car out.
can anyone shed any light on the problem and stear me in the right direction to get it rectified?
Many thanks, Mo
Old Aug 30, 2011 | 06:21 PM
robby363's Avatar
Default Re: One for you technical guys
Have you ever replaced the intercooler pump? It sounds like that could be the problem.
Old Aug 30, 2011 | 06:30 PM
times 2 on the inner cooler pump...common problem....check out the threads on here about "replacing the inner cooler pump".... stock bosch, CM30 Johnson, and the Ford Lightening pump all will work...
Old Aug 31, 2011 | 12:42 AM
11 FEB's Avatar
Thanks guy's
But do any of the error codes relate to the intercooler pump?
Old Aug 31, 2011 | 01:55 AM
Mimi05SRT6's Avatar
Intercooler pump for sure. Have it replaced and reset all the codes and you should be fine.
Old Oct 10, 2011 | 12:08 PM
11 FEB's Avatar
Spot on guys intercooler pump totally knackered
pop49
Sep 30, 2015 11:14 AM
rmcdaniel12
Sep 21, 2015 10:58 AM
Ed Mahoney
Sep 20, 2015 10:35 PM
cdcrone123
Sep 18, 2015 08:18 PM
8ighth Wonder
Sep 18, 2015 12:05 AM
