Supercharger problem
Old Apr 3, 2012 | 09:12 AM
11 FEB's Avatar
Default Supercharger problem
Just had the SRT6 serviced and have been told that it has slight supercharger clutch "chatter"
Anyone know of a quick fix? can the clutch only be renewed? or does it mean a new complete supercharger?
Old Aug 30, 2012 | 05:42 AM
11 FEB's Avatar
Default Re: Supercharger problem
Bump,
I am still having problems with this, can anyone point me in the right direction to fine out if parts for the supercharger, such as the pulley/clutch assembly, are available.
Old Aug 30, 2012 | 10:21 AM
waldig's Avatar
Talking Re: Supercharger problem
Id steer you to see Rob at Needswings, pm him at his name , he'll assist you. Woody
Old Aug 30, 2012 | 10:43 AM
Is this the OEM pulley?
What is the gap on the pulley plate and magnet?
I guess it is uneven. Maybe loose rivets? Bearing?
More info required.
A used OEM pulley can be had from $200 - $300.
Old Aug 30, 2012 | 01:13 PM
More info required.
and right now you have two choices of aftermarket performance pulleys on the forum for sale is the code 3 (just search the bold) and Rudy has a 62mm pulley for sale .jim
Old Aug 30, 2012 | 04:18 PM
11 FEB's Avatar
Had the rivits tightened a few months ago 4000 miles ago, it cured the problem for a while but now chattering again. Don't think it's just the pulley, sure it's the clutch.
Old Aug 30, 2012 | 04:53 PM
The two, pulley and clutch plate, are connected by a spring and held with rivets at both ends.
Can you turn the clutch plate back and forth?
Old Aug 30, 2012 | 05:21 PM
maybe you don't have enough clearance or you have tooooo much clearance between the back plate of the pulley and the clutch jim
Old Aug 31, 2012 | 03:03 AM
11 FEB's Avatar
The larger wheel/pulley closest to the supercharger will spin freely, then there is a gap of approx .5/1mm to what I assume is the clutch plate. this plate will not rotate at all no movement but will travel in and out if you know what I mean, this is what I think the chatter is.
The chattering only happens at low rev's as the car comes to a halt, once on tick over it stops chattering.
Idealy I want to replace the clutch if it is an available part, rather than repair it. without having to replace the whole supercharger.
Old Sep 4, 2012 | 07:46 AM
11 FEB's Avatar
No one help me out with part numbers? alternative part?
Have tried google but drawn a blank
Old Sep 4, 2012 | 07:58 AM
that is because we though you knew that the only way to get a new pulley is ordering a $7,000.00 supercharger,, but you can get a aftermarket performance pulley on the forun and you might find a person that is selling a stock one,,
from the dealer,,you need pulley you have to order a supercharger, it comes with the pulley
do a search for pulley and look for a pulley for sale. jim
Old Sep 4, 2012 | 10:12 AM
11 FEB's Avatar
Thanks Jim, no I didn't know but was assuming that it would be the case .So does a pulley come with the clutch assembly? again I am only assuming that the pulley is just a pulley!!!! and replacing just the pulley is not going to solve my problem
Old Sep 4, 2012 | 10:52 AM
The gap should be about .012" - .015" (.3 -.4mm).
Is that the standard pulley, I assume it is. The gap should be even all around as it should sit on stops.
Old Sep 4, 2012 | 01:06 PM
Just a pulley.
One of the things you might want to do is remove your pulley, inspect it, make sure the rivets are tight, then you can look at the magnetic clutch, to see if it has any damage it will have where marks on it.
To remove the pulley, take the bold title the end of the pulley using either a belt wrapped or you can break the bolt loose, sometimes with everything still hooked up, once the bolt is loose( loose not remove), then remove your belt.
If the pulley slides off, your good now inspect everything if the pulley does not slide off take two screwdrivers and tap,,,,, I said tap, not bang a screwdriver down a little as the pulley moves forward at one point it will get loose and come off. Don't lose the shims, count them, make sure you get the same amount going back or maybe less if the clearances to wide., If you take some real good pictures and post them, maybe myself or someone else can look at it and tell you if there's anything wrong. good luck, Jim
Old Sep 5, 2012 | 12:15 AM
itsky's Avatar
I have my stock pulley that I may be willing to part with. Let me know.
Old Sep 5, 2012 | 02:40 AM
11 FEB's Avatar
Thanks, but the pulley is not my problem, it's the clutch mechanism!
Old Sep 5, 2012 | 08:39 AM
jmswllms's Avatar
Were you told it's a bad supercharger coupler? New one COUPLING. Electric Clutch. for CHRYSLER CROSSFIRE (2005, 2006) (05189896AA)
also called supercharger pulley.
Old Sep 5, 2012 | 10:48 AM
The clutch plate is part of the pulley assembly and cannot be replaced on its own without some serious work.
I asked before if this is an OEM part as some after market parts had spring problems, The gap should be as I stated before, your gap seems excessive and could lead to chatter because it is too far from the magnet and this could cause spring failure due to overstretching.
You had an offer of another pulley and if the pulley springs are ruined you would be advised to take the man up on his offer.
Attached Thumbnails Supercharger problem-634035559_srt_6pulley3_122_1176lo.jpg
Old Sep 5, 2012 | 01:22 PM
11 FEB's Avatar
aha! at last!!! so the clutch (as I call it) is part of the pulley assembly
Yes mine is OEM so who has one for sale and at what price? The price in the link posted by jmswllms is a bit silly could buy a new complete supercharger for that price (so I have been told)
Old Sep 5, 2012 | 02:52 PM
jmswllms's Avatar
If you think the pulley price is silly, you will really giggle at the supercharger price.
SUPERCHARGER. Supercharger & Related Parts (SUPERCHARGER. . ST. Required: 001) for CHRYSLER CROSSFIRE (2005, 2006) (05143091AB)
