Battery Location?
Old Jan 20, 2013 | 03:14 PM
pct's Avatar
pct
Default Battery Location?
In preparation for the arrival of my new purchase can anyone tell me where the battery is located in a Crossfire, is it under the bonnet or in the boot?
My car will be used at weekends mainly and as it will spend quite a lot of time sitting in the garage it will be connected to a battery maintainer and i'm just trying to work out if I need to use an extension lead or not.
If anyone has a photo of the actual battery location it would be helpful
Old Jan 20, 2013 | 03:19 PM
Default Re: Battery Location?
In UK, left side ( passenger ) under the bonnet next to fender and firewall, easy to see and access.
( BIG NOTE : If you see that it is a white top Varta, beware ! That is an original battery and long past it's useful life )
Old Jan 20, 2013 | 03:22 PM
Ottawa John's Avatar
I wasn't aware that the battery location was reversed for right hand drive cars. hmmmm. I have a maintainer on mine all through the winter with an extension cord. Works great. So regardless of which side it's on, it's under the "bonnet" in the back corner and you should plan on an extension cord. What do you think, 180?
Old Jan 20, 2013 | 03:31 PM
pct's Avatar
pct
Thanks Alax/John. i'd spotted some info about the white Varta's whilst googling for the location earlier, i'll check on that, I intend to keep it hooked up to a 500mah maintainer whilst its in the garage just to keep it topped up as from experience the alarm/immobiliser drains batteries when parked for long periods, I used to keep my Mitsubishi GTO hooked up to the same thing (best £5 I ever spent from Amazon) and it was always ready to go.Name:  unnamed.jpg
Old Jan 20, 2013 | 03:35 PM
as to a picture, take a look at my sig picture and mentally flip it 180 degrees ....
or this gallery picture :
https://www.crossfireforum.org/forum...-0979-545.html
Old Jan 20, 2013 | 03:41 PM
pct's Avatar
pct
Easier still I turned my laptop upside down that puts it in front of the drivers side firewall, perfect for plugging in without having trailing cables for anyone to trip over in the garage.
I dont care about anyone falling over, only if they fall onto the car and damage it
Old Jan 20, 2013 | 04:47 PM
waldig's Avatar
I used the connectorized lead with cable out thehood under wiper. Now plus and unplug is but a sec. And hood is shut. You can put a card on whiper to doubly remind you its on trickle charger. If u forget, it will pull off without major concern. Woody
Old Jan 20, 2013 | 05:24 PM
pct's Avatar
pct
Good idea Woody, i'm thinking of putting a break connector into the lead, and hardwiring the terminal connectors in place of those clips so that i can just pull the connector & go.
A picture from UK kens gallery.
Old Jan 20, 2013 | 05:48 PM
pct's Avatar
pct
Looks like its on the passenger side then, no problem its still handy for plugging in. it looks like they re-locate the battery depending on if its left or right hand drive to give room for the brake servo.
Old Jan 20, 2013 | 06:07 PM
Yes, that's what I said awhile ago :
Old Jan 20, 2013 | 07:59 PM
A pic is worth a thousand words.
Old Jan 22, 2013 | 02:09 PM
Dal's Avatar
Dal
I too use an optimate on mine while it's being stored. A habit I had when I had the bikes
And if your ever stuck for a picture just click on the link under my signature picture, theres a few there
Old Jan 22, 2013 | 05:15 PM
pct's Avatar
pct
Great photo's thanks for the link, where was the meeting? looked a bit like Brooklands?
Old Jan 22, 2013 | 05:36 PM
Dal's Avatar
Dal
Yes your right it was Brooklands it was my first meet with the Crossfire group. There not a bad lot (well most of them ) it was a mad day the weather couldn't make up its mind so it was sunny one minute and raining the next.
Old Jan 22, 2013 | 05:46 PM
pct's Avatar
pct
Yes I noticed roofs up and down in the photo's
Thought it looked familiar, I went down there years ago in my first sports car, and managed to sneak it past security onto the banking and grab this shot.
I guess I wont be making many meetings unless you all fancy a trip over here to sample the TT course one weekend in the summer, quite a few car clubs do that, and i'd be happy to get info on ferries and hotels for you all.
Old Jan 23, 2013 | 05:02 AM
Dal's Avatar
Dal
The group did something similar a few years ago (2009). You may even spot your car in the group.
Brooklands 2009 Video - UK Crossfires
If you haven't signed up already make you do at Newsletters - UK Crossfires as there should be a 2013 Newsletter coming out anytime soon
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Steven 4190
Nov 25, 2015 10:12 AM
Reliableron
Oct 17, 2015 10:19 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
Valk
Sep 17, 2015 11:43 AM
