Heating and Air Con Problem
Old Feb 3, 2013 | 06:48 PM
Middleman4's Avatar
Default Heating and Air Con Problem
I had a problem with my Crossfire insisting on blowing hot air regardless of any temperature settings on the heating system. My local automotive electrician diagnosed the fault as being the motorised valve that turns the hot water on and off. For £300 he kindly replaced the valve and it worked for a week or two. Now I need to select hot or cold before I start the engine because once I get moving the heating controls have no effect at all. The good old electrician has offered to have a look at it for me again but he says that he thinks I need a replacement heating control system which costs over £600. A grand to be able to choose the cabin temperature seems expensive. Can anyone offer any insights or advice.
Old Feb 3, 2013 | 07:51 PM
Default Re: Heating and Air Con Problem
There are two valves, one for the passenger side and one for the driver. Which valve did he replace or was it both?
You say you have to select hot or cold, does that mean turning on the AC switch?
Old Feb 4, 2013 | 04:57 AM
UK ken's Avatar
Hi Had a simlier problem....I fixed it myself. at no cost!
Will PM you.
UKKen.
Old Feb 4, 2013 | 09:32 AM
Originally Posted by UK ken
Hi Had the same problem....I fixed it myself. at no cost!
Will PM you.
UKKen.
I think it would be better to put the possible fix up for all to see. This is an open forum after all.
Old Feb 5, 2013 | 06:47 AM
UK ken's Avatar
[QUOTE=onehundred80;722462]I think it would be better to put the possible fix up for all to see. This is an open forum after all.
Agree.. PM was a contact number. If my fix is the answer I will certainly post it.
UKKen.
Old Feb 6, 2013 | 05:57 AM
11 FEB's Avatar
Default
[quote=UK ken;722601]
you tell em Ken!!
UKKen.
Kodebuster
Nov 5, 2020 04:06 PM
waldig
Sep 2, 2015 11:02 AM
waldig
Jul 30, 2015 07:39 PM
waldig
Jul 20, 2015 08:10 AM
Seawolf
Jul 12, 2015 06:20 PM
