Auto gearbox leaks
Old May 22, 2013 | 02:39 PM
Dazd's Avatar
Unhappy Auto gearbox leaks
Hi folks, can anybody help me find a reconditioned automatic gearbox, mines sprung a major leak and needs refurbishing. Thanks. Dazd.
Old May 22, 2013 | 03:34 PM
abssorb's Avatar
Default Re: Auto gearbox leaks
My XF auto had quite a bad leak and I got it serviced at a Merc specialist. £150 for fluid, filters, inspection and to repair leak the part was £20.
Old Jun 3, 2013 | 07:20 AM
Grubnut's Avatar
These are Mercedes 722.6 boxes and they are notorious for the nasty plastic seals on the conector to the Gearbox ECU failing.
One of the symptoms (apart form an obvious leak) is transmission fluid leaching up through the loom and filling either or both the the foot well and the Transmission ECU with Transmission Fluid.
This leak will be from the connector at the front of the grearbox on the drivers side.
If it is this, and you are even remotely mechanically competent, it is an easy DIY job and the total proper Chrysler (Mercedes) parts should cost about £10.
Hope this is all it is.
Old Jun 3, 2013 | 07:33 AM
here is the DIY :
https://www.crossfireforum.org/forum...-ta-daaaa.html
Old Jun 3, 2013 | 03:31 PM
Dazd's Avatar
Cool Re: Auto gearbox leaks
Thanks for the information, I've had the box re-furbished at a specialist, so we are just putting this back into the car. Hopefully I can get this up and running before the sunshine runs out. Dazd
minimayhem
16
Aug 23, 2016 07:47 AM
Blackktieguy
21
Oct 26, 2015 12:32 AM
Dementors
Sep 30, 2015 07:46 PM
maxcichon
Sep 30, 2015 11:38 AM
williammt
Sep 6, 2015 11:23 AM
