Brake Pad Warning
Old Oct 4, 2013 | 09:15 AM
Robskytoon's Avatar
Default Brake Pad Warning
Ok so now I am confused by car - driving home the pad indicator started to flicker then came on. So knowing how these normally work braked gently just to check and light goes off! Drive another few miles same again.
Pads are Red Stuff so guess someone in past had them fitted they look at quick glance and feel that other pads are about 10mm face to backing plate - would have pulled wheels off but monsoon started any observations folks
Thanks
Old Oct 4, 2013 | 11:32 AM
Robskytoon's Avatar
Default Re: Brake Pad Warning
I have a theory which I can test tomorrow - a sensor wire has moved and touching edge of disc hence flicker as soon as brake pad moves wire comes off light goes out. Done normal test key in ignition turn all lights on start engine all lights off press brake pedal hard - no light
Old Oct 4, 2013 | 11:34 AM
UK-SRT6's Avatar
Wouldn't expect the light to come on with 10mm left on the pads is that both sides of both the disc? Had you been heavy braking and got them over hot??
Old Oct 4, 2013 | 12:51 PM
Robskytoon's Avatar
Hi Mo
Started raining as I was about to crawl under so not checked inner but would expect them to be about same. No done about 3 miles in 30 and 40 limits will pull wheels off tomorrow afternoon (been volunteered to go orienteering) not like last week when moron came straight over from left on mini roundabout then did brake heavily and swear too as did guy opposite but he had a bit more warning!!
Regards
TonyB
Old Oct 5, 2013 | 10:09 AM
Robskytoon's Avatar
So pulled both fronts off to have a look - pads OK - as guessed offside sensor wire just touching disc moved it away put everything back and all OK the disturbing thing was all bolts were tight except security bolts on both sides hardly any effort to undo - something to check I think after few miles having wheels off or new tyres fitted!
Old Oct 5, 2013 | 10:12 AM
Robskytoon's Avatar
BTW got quote for new pads fitted (just in case) from a tyre centre £59.18 !!! Pads would have been Drive Tec.
Old Oct 5, 2013 | 01:05 PM
PNA's Avatar
PNA
Pads .may be fine. Senors go bad. Mine did. Replaced the sensors and pads anyway.
Old Oct 5, 2013 | 04:37 PM
Is it possible the security bolts have tapered seats fitted by mistake and not locking down in the ball seat of the wheels?
Probably not but ........
Old Oct 6, 2013 | 03:14 AM
Robskytoon's Avatar
Hi
all the bolts are taper versions on mine and taper seatings in wheels
Old Oct 6, 2013 | 03:15 AM
Robskytoon's Avatar
Hi
chturner
19
Oct 14, 2019 04:42 PM
RamblinShamblin
Aug 12, 2017 10:55 PM
8ighth Wonder
Dec 15, 2015 01:42 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
ritous1
Sep 26, 2015 01:27 PM
