interesting first day of ownership
Old Dec 11, 2013 | 03:56 PM
bigade's Avatar
Default interesting first day of ownership
26 miles done on my first day of ownership.
Started with spoiler switch flashing and spoiler refusing to go down when I stopped.
left it parked with it up.
Came back to it, drove off and it went down but didn't come backup while driving,
BAS ESP light came on and stayed on though.
Stopped at local garage, restarted and there was what sounded like relay going mad from behind the dash, chattering away.
Got it home and hit the remote lock and only one side of indicators flash to indicate locked.
I had to laugh, reminded me of my alfa GT i had a few years ago!
Ade
Old Dec 11, 2013 | 05:04 PM
pct's Avatar
pct
Default Re: interesting first day of ownership
Did you buy privately or from a dealer? regardless if this is all happening on day one I would be going back to speak to the seller as these are obviously pre-existing faults.
Old Dec 11, 2013 | 08:03 PM
Osofast2's Avatar
check the battery make sure it's not the original, usually this is caused by bad battery, and yes a bad battery will cause the symptoms
Old Dec 11, 2013 | 08:21 PM
That is a good place to start. The car is very sensitive to having right amps to just about everything, or it will do strange things. Look under the floor cover on passenger side, as well in the trunk area for water. Moisture will also cause things to happen...good luck...
Old Dec 11, 2013 | 11:33 PM
Bay Cruise's Avatar
Check out this post where I listed a few things that you are experiencing.
https://www.crossfireforum.org/forum...ant-forum.html
Old Dec 12, 2013 | 04:25 PM
bigade's Avatar
thanks for that link.
Looked at my battery this morning - 'chrysler' written on it!
That'll be 10 years old then! I'll bung a new one on and see how I get on.
Todays driving:
Spoiler stuck up but no BAS ESP light on.
Driving home, spoiler stayed down for the first 5 miles, then chatter of a relay and the spoiler goes up and the switch flashes. I find it all amusing
Old Dec 14, 2013 | 09:44 AM
DRUMMY's Avatar
Taken the fuse out of my spoiler.
Had no probs atall just bleeps a warning sound
around 90 MPH, which i use to keep my speed below.
Old Dec 18, 2013 | 04:53 PM
bigade's Avatar
cheers drummy.
Its been into the local garage today for oil and coolant change.
Had it scanned and no faults logged.
Having looked on the forum, the only relay that is behind the dash seems to be the electric seats so i presume this it the one 'chattering' from time to time.
The battery is being changed at the garage, seems a reasonable place to start as its still on the original one.
Ade
Old Dec 18, 2013 | 05:51 PM
xfchris's Avatar
hi ade...I sometimes get a clicking sound from under the glovebox, found this thread which sounds like the sort of thing I get.....https://www.crossfireforum.org/forum...mpartment.html .....haven't looked into it too deeply as it dosent happen very often and not too bothered at the moment, maybe what you are hearing....chris
Old Dec 18, 2013 | 06:09 PM
Bay Cruise's Avatar
Don't want to go off subject but Chris we sold our Route 66 PT for my Crossfire.....
Old Dec 19, 2013 | 12:43 PM
UK-SRT6's Avatar
So you run with out the spoiler not working??? you are aware of why it was fitted??
Old Dec 20, 2013 | 04:56 PM
bigade's Avatar
to look cool?
Old Dec 21, 2013 | 04:29 AM
Robskytoon's Avatar
Hi Mo
I think his answer says it all - Merry Christmas to you and Gill
Old Dec 21, 2013 | 01:18 PM
UK-SRT6's Avatar
Originally Posted by Robskytoon
Hi Mo
Yeah!!! no comment
Same to you and yours, have a good one
Old Dec 28, 2013 | 04:20 PM
bigade's Avatar
ok, new battery fitted.
ESP light still on and spoiler up with flashing light.
Over 90 audible bleeping.
Guess i need it scanned by a decent scan tool - see what code we get up
Old Feb 28, 2014 | 05:46 AM
DRUMMY's Avatar
Hi Bigade
Would love to here the latest on your probs
All the best
Drummy
Old Feb 28, 2014 | 04:01 PM
bigade's Avatar
ok, micro switch on the spoiler motor broken so the car doesn't see the spoiler up and thinks its down.
Brought a new micro switch from maplins but have to take motor out to fit it.
Started using brake fluid this week.
Ade
Old Feb 28, 2014 | 06:00 PM
pct's Avatar
pct
Ade
You need to find out quickly where the fluid is going!
How does the pedal feel? is there any tendency for the car to pull to one side under braking? can you see any fluid on the ground when you move the car?
Old May 3, 2014 | 01:30 PM
bigade's Avatar
heavily leaking brake pipe under the middle of the car.
rear disks heavily pitted.
Old May 12, 2014 | 05:04 PM
bigade's Avatar
brake pipe corroded through where the two rear lines are kind of joined together. Both replaced, new discs,pads and fluid.
