Headlamp unit advice needed
Old Jan 25, 2016 | 07:29 AM
Fozz's Avatar
Default Headlamp unit advice needed
Hi,
I've got a problem with the right side headlamp assembly.
The main (high) beam projector housing is out of alignment. Sends the light beam out to the right by about 30 degrees rendering it next to useless.
Can this be fixed or do I have to bite the bullet and get a replacement unit?
Thanks
Old Jan 25, 2016 | 08:25 AM
Default Re: Headlamp unit advice needed
Originally Posted by Fozz
Hi,
Thanks
Attachment 36706
Attachment 36707
Are you sure that the bulb is in correctly?
If the bulb was changed recently then that may be the cause. The alignment can be possibly be set straight but it is something that rarely needs doing unless someone put the bulb in wrong and tried to readjust it. That would show up if the bulb was now set correctly in its seat.
Old Jan 25, 2016 | 11:05 AM
Fozz's Avatar
Thanks onehundred80
I think you've hit the nail on the head. The bulb is in correctly, but at some time it has been so over-adjusted that the whole thing has come off. I was turning it and nothing was happening.
Once I could get proper access by removing the coolant reservoir I was finally able to get the adjuster to bite again and now it's all sorted.
Thanks again for you help
Old Jan 25, 2016 | 11:48 AM
Good deal !
That is what I was going to suggest, the adjuster had 'slipped the cog'.
Jan 30, 2016 04:40 PM
Dgiomatch1
Jan 22, 2016 07:10 PM
summerstar
Jan 17, 2016 09:02 AM
summerstar
Jan 15, 2016 10:11 PM
steps
Dec 29, 2015 11:03 AM
