RCM and CPS problems
Old Nov 17, 2018 | 12:07 PM
jeffreyt's Avatar
Default RCM and CPS problems
as you will see I'm seriously thinking about a Crossfire and been doing a little digging into weak spots.
Seems the RCM and CPS come into the problem areas.
Are either of these a given ie they will happen eventually or only a few cars affected?
Thanks
Old Nov 17, 2018 | 12:45 PM
Default Re: RCM and CPS problems
Thanks
When you read a forum like this you get to see the problem areas, but you should keep it all in perspective. If you went to a hospital you would see a lot of sick people but you would not automatically think that everyone everywhere is sick.
Sure the RCM can cause problems but it can be examined and a fix applied to any obvious problem areas. The CPS can cause problems as well, just carry a spare and the tools install it.
Buy a car that has been well maintained not beaten to death. Then look here for solutions for any problem that may arise, do not go to a dealer.
Old Nov 17, 2018 | 12:58 PM
Replace the CPS every 50K and it is doubtful you will have any trouble with that issue.
Thanks
Old Nov 24, 2018 | 09:33 AM
marlam's Avatar
Re: If you do have trouble with the RCM.
I had a problem last year which turned out to be the RCM. I had some trouble trying to get it fixed here (in the UK) and ended up sending it to a guy "on this forum" in the USA who tests it, repairs any bad connections etc and sends it back. All it cost was the postage both ways and a small charge for the repair. No need to buy a new RCM and no problems with it since then. Hope this helps.
Generally, my only advice would be to use the car if you buy one. If you SORN it and lock it away for months over winter (as I have done many times) you might end up with problems - that has been my mistake.
28
Aug 26, 2021 01:05 PM
Hal B
Sep 18, 2016 04:02 PM
victorlautreamont
Jul 13, 2016 07:50 PM
nick78ru
Jul 16, 2013 09:22 PM
GDrag
Aug 24, 2012 02:50 PM
