View Poll Results: Secondary air injection pump
100.00%
Chrysler crossfire
50.00%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Old May 17, 2023 | 01:25 PM
Daviddonnelly's Avatar
Default Secondary air injection pump
Hi all, first time posting, having quite a bit of work done to my crossfire, can any help or advise were to buy a secondary air injection pump, no engine management light on or causing any issue but will need replacing. Many thanks
Old May 17, 2023 | 04:08 PM
Default Re: Secondary air injection pump
Try eBay.
What’s wrong with it, they can be fixed sometimes.
Old May 17, 2023 | 04:45 PM
Default re: Secondary air injection pump
Intermittently now again engine management lights comes on and diagnosed as secondary air injection pump buts it only happens on the odd occasion and then management light goes off.
Old May 17, 2023 | 05:18 PM
Could be a relay sticking in the RCM?
Old May 17, 2023 | 08:13 PM
manlaw38's Avatar
Talking Re: Secondary air injection pump
My Crossfire does same thing the air pump works and the check engine light comes on after driving car to one town over aprox 10 miles then I must reset the check engine light to have the light to go off. I bought a new RCM and it started doing this after about 10 months of having the RCM installed because it was doing this before I bought the new RCM. So I have no idea what could be wrong with it. The check engine light will come on once I restart the engine after I come home from doing errands like light driving, the check engine light doesn't come on right away. The code says that the air pump is at fault. I went to the junk yard bought a used air pump and it does the same thing you can hear the air pump engage once you start the car. My emissions is due next month and I need to fix this because I asked for an extension once already. Once the car is 20 yrs old I can get antique classic tags which exempts me from emissions test. The car runs great .Can't wait to get this over with. I have replace all the coil packs and spark plugs and plug wires all new injectors and I am soon to change the fuel filter before next month just for maintenance I have installed new clutch and all fluids have been changed from power steering to rear end and new trans fluid. once I get this fixed I want to put a larger throttle body off a V8 Mercedes which I have ready to install ,I love my little red coupe.
Old May 18, 2023 | 02:51 AM
Could be a lot of things causing it i guess
Old May 18, 2023 | 06:54 AM
manlaw38's Avatar
Thanks for you'r response, These cars have their gremlins . As I mentioned my Crossfire runs great but these cars are very touchy especially the electronic gremlins .I will see once I change the oil and fuel filter and fuel pump this week end. I have replaced many parts on this car since I bought it in 2018 since it was a high mileage car when I got it. The car had no dash lights on when I bought it, it all started once I had the skreem failed and I had a forum member do a skreem delete in 2020-21 when it failed. As I mentioned this car was unloved when I got it and since I have had a love affair with this car since 2018 when I bought it. I started to replaced maintenance items as they had began to fail, there is not much else left to replace unless I replace the drive train but why would I do that when it runs like a new car LOLOL. Only thing which has not worked since I bought was the AC compressor which had froze up and I have am ready to install. a new system..
Thanks again for you'r responses
Old May 18, 2023 | 12:58 PM
tighed1's Avatar
This is a known issue. Check the air pump relay contacts in the relay control module. Bet that they are burnt!
I've replaced a ZILLION of these relays. If interested in getting your RCM refurbished, email tighed1@hotmail.com for the details.
Old May 18, 2023 | 01:05 PM
Thank you i will check this and be in contact.
Old Jun 29, 2023 | 06:19 PM
Ranger413's Avatar
Ok, some videos say that you can test secondary air pumps by connecting directly to the terminal. Does this work for ours as well? I don't think the pump is coming on at all for me.
Old Jun 30, 2023 | 12:39 AM
tighed1's Avatar
Just manually close the air pump relay and it should turn on. Don't even have to turn the key on. Might want to take a look at the contacts. If they're burnt replacing the relay is your best bet. LMK
Old Jul 2, 2023 | 04:20 PM
Ranger413's Avatar
ok I am not aware how to close the relay manually, but I did take a look at it. There is a little discoloration, but nothing like the pic you attached
Old Jul 2, 2023 | 04:21 PM
Ranger413's Avatar
Old Jul 2, 2023 | 04:50 PM
You can try putting a rubber band on it?
Old Jul 3, 2023 | 02:36 AM
tighed1's Avatar
Take the little spring off then lift the braided wire over the top of the relay.
Pull the relay arm out and then look at it.
Old Aug 7, 2023 | 02:12 PM
davidperez12's Avatar
Hola
como hiciste la eliminacion del skreem?
mi crossfire enciende solo 1 segundo y se apaga
lo puedo hacer tres veces
despues ya no me deja hacer nada y desconecto bateria
ya programe 2 llaves y nada
el carro lleva estacionado 2 años
Old Aug 12, 2023 | 06:04 PM
Ranger413's Avatar
Ok, I actually tested the air pump directly and it was bad. Swapped in the new and everything was good for about a week. Now it's throwing P0410 again. I will take a look at the relay. The new pump is still good.
Old Aug 12, 2023 | 06:12 PM
I would like to know what the poll was intended to show?
Mdcrossfire
May 20, 2019 07:35 PM
orbit398
Jun 4, 2016 06:26 AM
btball
Aug 31, 2011 07:29 PM
BigWho
Nov 17, 2010 12:26 PM
BigWho
Nov 16, 2010 05:28 PM
