**WEBSITE** Functions / Questions/ Suggestions Etc **NOT CAR RELATED** THREADS / DISCUSSIONS Post suggestions or questions regarding the FORUM FUNCTIONALITY etc. The Moderators will monitor postings here
Search feature on the Forum
Old Dec 20, 2015 | 09:42 PM
Larry Hitze's Avatar
Default Search feature on the Forum
Is it me or is the search feature here on the forum different?
When I use it I might get one relevant result but the rest just look like a list of the threads that don't have anything to do with what I am looking for. Am I not using it right? All I have been doing is typing something in the search block.
Old Dec 20, 2015 | 09:53 PM
syfi's Avatar
Default Re: Search feature on the Forum
I've always felt the same way Larry. The search over on Benzworld is more like the way this one should be. It shows the first 5-10 lead post that contain the search item. Much more efficient. I sometimes get better results using the Advanced Search under the "Tools" dropdown.
Old Dec 20, 2015 | 10:10 PM
Thanks, Ill give it a try.
Old Dec 20, 2015 | 10:14 PM
I find the same results unless I use the "advanced search" in the drop-down box under "tools"
Old Dec 21, 2015 | 10:38 PM
I gave that a try by using "battery" same bad result. Just 1 relevant result.
Old Dec 21, 2015 | 11:40 PM
Advanced search using the word "battery" and choosing from the dropdown box "search title only" might work
Old Dec 22, 2015 | 12:04 AM
Using just the word battery will get all posts that mention the word. You have to refine the search with another word or two.
Using the advanced search is the best, as you can specify the poster, the forum it is most likely in etc.
Old Dec 22, 2015 | 05:09 PM
Thanks Gary, I've just now played around with this way and it seems to work much better! Much appreciate everyone's help. I guess I didn't try enough drop down boxes to get the results I wanted.
Old Mar 20, 2016 | 12:47 PM
Another thing to keep in mind, when you are listing key words to search on, if you put the key words in quotes, the search will look for threads that have that entire phrase. If you don't use the quotes, it will look for any thread that has any of the words. I was looking for threads on starter motor. Surprising what comes up if you search for starter motor (154 threads) or "starter motor" (85 threads). The latter found what I was looking for.
I've tried looking for info using "Search Title Only" and other drop down boxes. Problem is we as a group tend to digress in many of our threads from the original point. I know I'm guilty of this at times. And so there might be valuable information in a thread that is completely unrelated to what you're looking for.
It is what it is!
Later,
Old Mar 29, 2016 | 11:42 PM
It is what it is!
Later,
Thanks for the tip!
onehundred80
Nov 20, 2018 09:01 AM
deerhunter
Feb 7, 2015 07:45 PM
onehundred80
Apr 2, 2013 07:40 PM
James1549
Jun 18, 2009 11:43 AM
AZ Outlaws
May 8, 2004 02:32 AM
