Alarm Siren
Old Jul 7, 2021 | 09:58 PM
flaco1801's Avatar
Default Alarm Siren
I just purchased one from a dealer in Milford, C.T. I installed it today and it was a Bosch....I paid about 140 dollars and it should last till the replacement is 200 bucks....Is there anyone on/in the forum that replaces the batteries inside?....The newer sirens do not use the security bolt, they come with a threaded stud that needs a nut which is not included....not a bad job, worst part was cleaning and re assembly...
Old Jul 7, 2021 | 11:05 PM
Doc78's Avatar
Default Re: Alarm Siren
I am currently waiting on my batteries to arrive.
I am planning on replacing mine.
I will have to test mine after to see if any damage was made to the surrounding components.
I’ll let you know when I’m complete.
Old Jul 8, 2021 | 02:06 AM
flaco1801's Avatar
Thanks Doc....
Old Jul 8, 2021 | 08:26 AM
There are at least three versions of a suitable siren, at least one does not beep when locking the car just like the one fitted to the original cars, one that does beep and has the original mounting screw and another beeper with the mounting stud like yours, I have it.
In an earlier post of mine I give the numbers of the beepers, the original siren number is marked on it.
All these numbers are available by using search.
Old Jul 8, 2021 | 04:34 PM
flaco1801's Avatar
The post was an inquiry about any members that are replacing the batteries like D.J. does for the module....The comment about the stud screw was simply a statement because i had never read about the different configurations...
Old Jul 8, 2021 | 05:07 PM
Default Re: Alarm 🚨
You were wrong when you said they only come with studs these days, if you state something as being positively correct then on this forum you can be expected to be corrected when it is not 100% true.
We cannot let a factual error be taken as true.
Nothing spiteful was meant by words, I say there may be other sirens that fit as well as those I mention.
I do not say my reply is absolutely the full list.
I have a thread on here showing and listing some siren numbers, so I know of which I speak.
Old Jul 8, 2021 | 07:05 PM
flaco1801's Avatar
I never said 'only"..... I said i was inquiring if any member repaired these sirens.....Why do you need to say i stated something not factual?...Do you always need to be the the person who is always correcting others in a way that makes them feel uncomfortable.....In the short time i have been in this forum i can always count on you to be a stick in the mud....This is a forum of like minded people, you do not need to criticize every chance you get......There are ways to interject without making yourself feel better....
Old Jul 8, 2021 | 07:19 PM
I used the word ‘only’, you said ‘do not’, no real difference.
I said nothing spiteful was meant by my words and yet you still decided to get huffy.
Do you always take a negative attitude, so many of you do, god help America.
I have decided that I will give the forum a miss for a while, I am fed up with criticism from idiots like you who have been here five minutes, cannot use search and do not understand plain English.
Old Jul 8, 2021 | 10:51 PM
flaco1801's Avatar
I am sure many here will not miss your sarcasm.....As for name calling, the moderators should have something to say about your behavior....
Robingaton
Aug 8, 2023 04:50 PM
James1549
May 26, 2021 09:59 AM
Saridale
U.K.
Jun 21, 2019 09:34 PM
Vintage Fire
May 16, 2016 08:46 PM
Hawkske
Nov 2, 2014 10:01 PM
