losing air from rear tire
Old Nov 19, 2006 | 11:45 PM
porterhouse's Avatar
Default losing air from rear tire
I have a slow air leaking tire. About two weeks ago I check the tire pressure (after reading a thread regarding tire pressure, of course) on my rear driver side tire and it reads 24. So, I fill the air to 36 psi then after a week I check it again and it reads 20. What is the possible reasons for this to happen? Is this something the dealer can fix or replace? Or should I just go to local tire shop and have them check it out. I inspected the tire itself and it does not seem to be punctured anywhere. Thanks.
Old Nov 20, 2006 | 12:02 AM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: losing air from rear tire
i would take it to a tire specialty shop.
they will/can remove the tire and place it under water (large tank) to see where the leak is coming from... then reseal the tire bead or do an internal patch/plug combo.
Old Nov 20, 2006 | 09:51 AM
danimal's Avatar
You may also check the valve core (inside the valve stem) to make sure that it is seated properly. Squirt some soapy water into it and around the stem and see if it blows bubbles. If not, then it is definitely from the tire somewhere. Slow leaks like that can be hard to find.
Old Nov 20, 2006 | 11:36 AM
MY advice; just take it in to a tire shop. Remember you have no spare.
Old Nov 20, 2006 | 11:45 AM
Idaho's Avatar
Lightbulb Re: losing air from rear tire
Dan I know on cars that do not have TPM, using soap water to check the valve stem is the best method. However, I am wondering if that method is acceptable with the Crossfire since the TPM is in the valve stem. The service manual has the following warning regarding the cap to ensure moisture stays out of the stem:
Note: The cap used on this valve stem contains an O-ring
seal to prevent contamination and moisture from entering
the valve stem. Retain this valve stem cap for reuse. Do
not substitute a regular valve stem cap in its place.
I am now also wondering about the effect of the submersion tank on the TPM if the technician does not put on the valve cap.
Old Nov 20, 2006 | 12:20 PM
danimal's Avatar
Good points!!! My thoughts are that if it is leaking from the stem, then air pressure escaping is going to keep the moisture from entering. Either way, I would dry it out before replacing the cap. I wouldn't want it exposed to constant moisture but I'm not sure how else you would check it without exposing it to some temporarily.
HDDP's Avatar
Also, you may have a cracked wheel... Take it to the tire shop and have them put the tire on the other wheel and see if it follows the wheel or the tire...
Old Nov 20, 2006 | 09:44 PM
aptiva's Avatar
You can also use the soapy water method for the whole tire. You need to over inflate the tire and run soapy water over the thread. Over inflating will force the air out of the leak. If that doesn't work, I agree it's time to take it to a professional.
Old Nov 23, 2006 | 09:32 AM
I finally gave up and brought it to the local tire shop. They found a finishing nail tucked away inside the tread. Very tiny. Thank you all for great tips. I learn something everyday from this forum.
Old Nov 27, 2006 | 08:07 PM
feets's Avatar
Our cars use the ABS sensor to detect different wheel speeds. When a tire is low, that tire spins faster than the other side. A small pressure difference will cause that to happen.
Kodebuster
Nov 5, 2020 04:06 PM
tom2112
Jul 28, 2015 08:12 AM
axnguyen
Jul 21, 2015 11:41 AM
cjfine
Jul 20, 2015 11:58 PM
Buchacho
Jul 9, 2015 04:13 PM
