Rear camber "not adjustable"
Old Nov 24, 2006 | 02:13 AM
dynamicS's Avatar
Default Re: Rear camber "not adjustable"
Originally Posted by Kamjin
Okay... Now we're on a topic that I know A LOT about. I spent 2 and a half years doing alignments on top end cars in Ponte Verde, FL. I have done Porsches, BMW, Mercedes, NSX's, and many others. I went to alignment school for Goodyear, so these I know.
Before I go into this, I just wanted to let you know that if you had anything heavy in the rear of you car, even a golf bag, you can sometimes affect the Camber on any car. And the whole "locking the plate" thing, well I have never worked on a rack that you leave the plates locked to either measure or adjust a car. The only times that the plates are locked is when you are compensating the heads of the alignment rack. After that point you have to unlock them for the car to sit as natural as possible.
Looking at your specs that you have listed...
Your car I would think is pulling to the right. If it is doing that, I would guess that is not a very hard pull on most roads and sometimes pulls harder. That would be due to road crown. That is the camber they put on roads to help the rain drain off. Most cars come from the factory with a slight pull to the left to compensate for the crown of roads. Your Camber is sitting with your left tire leaning in more than the right, so that is what's causing the pull to that direction. If a mechanic tells you that Camber will not cause a pull... HE'S FULL OF IT! If your car is pull to the left, then you are having issues with one of your front tires and swapping the two fronts will cause it to pull the other way. In that case you might be in need of some tires, and if you just got new tires, you need to swap them to check first and if the direction changes take them back and say you have a "radial pull". I really don't see what else could be causing that problem. Your Caster is the only other thing that can cause a car to pull and with yours being even, its not that. Toe will not cause a pull. If your toe is way out of wack then your steering wheel will either sit off center, or you will get bad "waves" on either the outside or inside edges of the tire.
As for your Camber issue on the rear...
If you were coming to the shop that I worked at, I would recommend trying to drive the car the way it is for a short period of time. Maybe 2 weeks, and see what kinda wear pattern you get. .04 off is kinda close and might not show a large amount of wear. If the wear is minimal, then I would let it go and maybe just swap the rear after 10,000 miles or as needed.
so that you do not wear out your tires, keep check the inside edge for excessive wear. If the tire wears quickly, then I would see about correcting it. Which being that the rear is non-adjustable, you will have to get an aftermarket kit to correct the problem.
One thing that you have to keep in mind about German made cars. They are made to have strong amounts of rear Camber. Most American mechanics will be quick to try and set the rear Camber a 0.0 to reduce the wear on the tires which only has about a 50% chance of not wearing out the outside edges of the rear tire.
If you still need some more help, just email me and we can get in discuss this better. lod13roc@hotmail.com
Well you sound like you know your stuff. I was wondering what you might think about adding some more Toe Out to the rear of the cars' tire? Mine is showing a lot more thinning on the outside edge as compared to the inner and center part where there is lots of material left.
Old Nov 24, 2006 | 04:20 AM
Kamjin's Avatar
If your getting wear on the outside edge but not on the inside, that really sounds like a Camber issue. If you know your alignment is good, then toeing it out might help some. But that is only if the toe on the rear is toeing in while your riding down the road. It might be possible that you toe is slightly out of spec, or in spec but toed in a bit. One thing that most people don't know is that most German cars alignments are to be done with special tools to simulate driving conditions. Most techs, including myself, don't have the tools to get it just right so some cars will not align perfectly. For example, I remember that the correct way to align a BMW was to put 50 kilos in both front seats, a certain amount of weight in the rear, a toe bar in between the front tires pushing out, and it was suppose to have a half a tank of gas.
I consider myself to be a darn good alignment tech, but I just really picked up on the amount of crown on the roads in the area that I worked and kinda had my own little tricks that seemed to work in aligning German cars.
Now to get back to you, I would recommend checking the amount of air that is in your tires and see if its running low. That would make you ride on the outside edges of the tire and could add some excessive wear when cornering. Also look at the way you drive. If you take corners kinda quick regularly, then you can show some excessive outer wear due to the fact that our cars ride on low profile tires. This can be even more noticeable if your tires have a low tread wear. If your running the Michelin Pilot Sport PS2 tire, then your tread wear is kinda low and taking turns fast will easily wear the edges out compared to the Continental ContiTouringContact CW95, which is the other all weather OEM fit tires, which have a much higher tread wear.
Old Nov 24, 2006 | 02:38 PM
dynamicS's Avatar
I do have the Michelin pilots, and I have a tendency to carve hard into the corners.
I was thinking that instead of camber adjustment, that the Toe out would help more, since it keeps the wheel flatter than a camber adjustment would, I'm just trying to squeeze as much use out of these expensive pilots.
Old Nov 24, 2006 | 04:44 PM
HDDP's Avatar
Here ya go guys... This will help end your discussion and get your WHEELS STRAIGHT !
File Type: pdf
Old Nov 24, 2006 | 04:46 PM
Kamjin's Avatar
I think the only way your going to get more out of those tires is to ease up on the corners. I know, I know... That's where all the fun is, but thats also where you extra wear is most likely coming from. You got to understand that the PS2's are very high quality tires, but their strong point is also their weak one. With a low tread wear, you get better handling and improved ride quality, but the trade off is a short life span of the tire and much quicker wear under hard driving conditions.
HDDP you just brought back memories of looking up adjustment kits back in the day. I really do miss that job. The best part about being an alignment tech is that you have to test drive all cars before and after performing an alignment. Nothing beats aligning a top end car and "test" driving it on back roads in the middle of country. The most fun was a '91 Miata those, with a turbo set up pushing 289 hp. There was no such thing as going slow!
Old Nov 24, 2006 | 06:47 PM
crossfireGal's Avatar
HDDP & DynamicS, re: what's the problem & mountain out of mole hill, I don't think I posted anything misleading. I said explicitly from the beginning (see my second post in this thread) that 11 of the 12 dimensions (everything except rear right camber) was inside the specs but that my 1st issue was for $500 they should've been dead center, not at the right or left periphery of the specs as some of them are - I don't think that's unreasonable or high maintenance. Multiple others who posted to the thread concur.
And my 2nd issue was the right rear camber was out of specs "after" when it was in specs "before" - didn't seem right at least initially.
Kamjn, thanks for the info!!
Old Nov 25, 2006 | 11:34 AM
If you have one of the aftermarket kits installed to address the rear camber, does that invalidate the warranty for anything related to the rear suspension?
Old Nov 25, 2006 | 09:27 PM
HDDP's Avatar
Well, it's your bad for getting charged $500 for a $140 job... Right rear camber is probably off from lots of driver only / zero passenger miles... It has a tendency of squishing down the left side suspension... Only my speculation...
Have fun, but I would be pissed at the dealer not the car...
Old Nov 25, 2006 | 10:19 PM
HDDP, interesting idea on the driver only/no passenger phenomenon. That was quite possibly a factor though I'm convinced dealer error was another.
I agree with you that I should be mad at the dealer not the car. I am in fact mad at the dealer, not the car. I love the car and that's why I'm trying to take care of it. Had some bad experiences with the chain tire stores aligning it, so wrongly thought the dealer would take care of it - like you said my mistake. Now for everything I'll drive 150 miles to the guy I trust in Delaware - can't deal with the stealerships or the chain tire stores and know no independent mechanics closer to me.
usprb1976
Apr 4, 2024 04:57 PM
blackpepper
Dec 18, 2021 06:17 PM
Jonacross
20
Jul 17, 2017 11:19 PM
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
