Noise after setting the emergency brake.
Old Jun 7, 2007 | 04:29 PM
bsb's Avatar
bsb
Question Noise after setting the emergency brake.
After setting the emergency brake, sometimes there is a very loud metal to metal rubbing sound when I take my foot off of the regular brake. It is loud enough that people will turn and look. It happens about 10% of the time and is more common when parking on an up hill slope. Any ideas? The car is a new 2006 (?) with about 1,500 miles. It is a 6 speed stick convertible.
Old Jun 7, 2007 | 08:06 PM
Maxwell's Avatar
Default Re: Noise after setting the emergency brake.
do you hear it when driving or when your parked while the hand brake is pulled?
Old Jun 7, 2007 | 08:20 PM
DMS Xfire's Avatar
Sound like maybe a drive line problem, U-Joint bolt or mounts. Have the dealer check it out it's still under warranty, I hope.
Old Jun 8, 2007 | 12:07 AM
Maxwell's Avatar
what made you come to that conclusion?
Old Jun 8, 2007 | 12:52 AM
bsb's Avatar
bsb
Question Re: Noise after setting the emergency brake.
The noise occurs after the motor has already been turned off and the emergency brake has already been pulled as far back as it will go. After both of these things (engine off and emergency brake on), I take my foot of the regular brake and the noise occurs. It never occurs when I use my brakes while driving. The dealer claims it is normal and due to the fact that the emergency brake is cable operated. Anyone else have this problem?
Old Jun 8, 2007 | 03:34 AM
brhertel's Avatar
I have that too. The linkage of the E-brake needs to be lubed. My dealer did it for me.
Here's the link to the previous post regarding this issue:
https://www.crossfireforum.org/forum...ghlight=squeak
Old Jun 8, 2007 | 08:40 AM
bsb's Avatar
bsb
In your original post, you described the noise as a squeak when you get out of the car. Mine sounds like a metal to metal grind when I take my foot of the regular brake (engine off, emergency brake already on). I am still sitting in the car. Does that sound like the same thing you had?
Old Jun 9, 2007 | 11:21 AM
vladie22's Avatar
are you on an incline or a hill when it happens ? it is nothing more than the weight of the car moving itself slightly. since the ebrake handle is up, the rear pads are touching the rotor, the car moves slightly and the sound you hear is the rotor turning with the pad gripping it. happens to me all the time.
Old Jun 10, 2007 | 04:32 AM
brhertel's Avatar
I guess my noise wasn't a squeak, it was more of a metallic sound. It may be what the previous poster said as well.
Old Jun 10, 2007 | 02:26 PM
Maxwell's Avatar
Yeah, I get the metallic sounds too, it comes from the back of the car, maybe the disc brakes dragging or the emergent shoes rattling around on the disc hat.
Old Jun 11, 2007 | 11:14 AM
ShawnQ's Avatar
This noise is probably 'normal' from the rotors 'dragging' just a bit prior to the e-brake working.
Not sure if yours is louder than mine or not, or if it is just a bit of over-exaggeration, but mine does the same thing.
Set the e-brake, and then let your foot off of the brake pedal, and you'll hear the brake set. Not sure there is much you can do about it. It is probably a bit more excessive in these cars due to the lack of a rear seat and a trunk allowing a short distance and lack of sound-deadening between you and the rear axle.
SQ
ty_ty37
Jun 27, 2024 10:42 AM
livefreeordie
Sep 22, 2015 08:13 PM
Valk
Sep 17, 2015 11:43 AM
caseydeankopp
Sep 13, 2015 07:25 PM
BEATv1
Sep 10, 2015 12:58 PM
