Brake feel on used 2005 Limited Coupe
Question-
I bought a used 9K miles 2005 Limited Coupe Automatic. The brakes feel soft to the push- but stop the car well. No warped rotors, no noise.
I test drove a 2004 6 speed manual, and the brakes on that vehicle felt very stiff and stopped the car a little quicker.
I am assuming my brakes on my car I bought are stock- no leak in the master cylinder etc....
How should the brakes feel in my 'stock' 2005 Limited feel in the forums opionion?
Thanks
Thanks
Re: Brake feel on used 2005 Limited Coupe
Originally Posted by RPM
Perhaps the Crossfire you bought has aftermarket pads (Rotex Gold, etc.). I noticed that the Rotex Golds require a good bit more pedal than the stock pads.
Originally Posted by donschorr
Do you think that the brakes could have been changed with less than 9K miles on the car?
You'll notice that many members of the forum use Rotex Gold pads that produce very little brake dust.
Question-
Thanks
Thanks
Yes. Many owners switch the factory pads out due to excessive brake dust.
Question-
Thanks
Thanks
on
1 Post
The easiest way to tell if they are stock.........
1) clean your wheels with a microfiber cloth.
2) drive your car for 5-10 miles
3) take a white cloth and wipe your wheels again......if the cloth turns black the pads are probably stock.
I'm dead serious......the stock pads are that dusty!
On a seperate thought.......did you leave the 6m car in gear as you were stopping? I know I can downshift the car and slow down VERY well without any braking.
Also......do you know how long the car sat before you bought it......there could be fluid contamination issues, pad contamination, it could even be the tires.
Question-
Thanks
Thanks
The car sat for 5 months prior to me buying driven a total of 400 miles during that time at a car lot. The brakes are just mushy feeling, but work properly, I like a strong pedal. Tires great shape, stock Continentals perfect tread no cupping alignment perfect suspension perfect etc.
Thanks for your advice.
Originally Posted by Maxwell
I just installed the ceramic pads and slotted rotors, and yes I also found the brakes to be a little mushy. I need to install a set of SS lines I picked up on ebay, only $50 for this car. then pressure bleed the system, I'll get back to you onthis later, so no it's not the oem pads that feel mushy.
Don
The first thing I'd try is this......Start the car, leave in park (neutral if 6m), and press the pedal firmly and hold it there for a minute. If the pedal moves at all or slowly drops to the floor you more than likely have a leak somewhere. (caliper piston, abs unit, valving, lines) If the pedal stays in a firm position, i.e. doesn't move after it has been held for a little time, I'd probably just try to bleed the system and see if that helps.
This is all assuming that you are happy with the quality of your brake hoses.
Can you just change the front stock brakes and leave the stock brakes on the rear?
