Dumb Brake Question !!!
Old Apr 5, 2008 | 07:36 AM
Stogey's Avatar
Default Dumb Brake Question !!!
Ok, so I did a scan, no help ! Will the front brake rotors interchange with the rear ? The plan is this, I need to replace one of the rear rotors, but before I do that, if I can swap the fronts out with the rear, I'll order the drilled slotted rotors from BrakeWorld and Rotex pads for the front. Possible ???
I told ya it was a dumb question !
Just my Dos Centavos
Old Apr 5, 2008 | 08:00 AM
RPM's Avatar
RPM
Moderator
Default Re: Dumb Brake Question !!!
I don't believe they are interchangeable. The fronts are larger.
Someone may know better than I though.
Old Apr 5, 2008 | 10:18 AM
sowardcustoms's Avatar
They Don't Interchange... The Na Crossfires Have Vented Rotors In The Front Solid In The Rear.. Supercharged They Are Different Size Front And Rear But Are Both Vented...
PNA
Aug 30, 2024 02:06 PM
deerhunter
Jan 16, 2021 10:56 AM
xfireohio
Jul 20, 2020 12:03 AM
psuperti
Aug 30, 2015 12:08 PM
chturner
Aug 23, 2015 06:14 PM
