Pulse Vibration at High Speed
Old Apr 22, 2008 | 07:11 AM
pennstatebadboy's Avatar
Default Pulse Vibration at High Speed
This is strange. I put new wheels and tires on my 06 coupe and am now getting a vibration over 60mph. I can feel it in the steering wheel, gas pedal, shifter, and seat.
Here's what's really odd. It's not a constant vibration. It pulses. So, for about 1 second it will vibrate, then the shudder will fade until it pretty much stops vibrating; then back to vibration, then back to calm, and so on and so on.
Is this something that can be caused by improperly balanced wheels/tires? Is it a spacer issue?
The wheels are 18 in front and 19 in the back, like stock.
Any ideas?
Old Apr 22, 2008 | 09:10 AM
imabenz's Avatar
Default Re: Pulse Vibration at High Speed
This may not be of much help and its a bit stupid, but it may pinpoint the problem.
If you still have the old wheels and rims and they are the same size, you could swap them out one at a time to see if one of the new wheels is causing the problem. Or put all of the old ones on first to see if the problem goes away, then put the new ones on one at a time until the problem comes back.
Old Apr 22, 2008 | 09:40 AM
I do have the old wheels, unfortunately the tires were shot, so I had them removed.
I'm just confused by the nature of this vibration. I've never heard of a vibration that pulses instead of remaining constant.
Any clues as to how this could happen?
Old Apr 22, 2008 | 10:05 AM
RMADERMAN's Avatar
Had the same problem with my daughters SRTwhen I drove it up to Daytona. When I got home after the annoying pulse as you discribed it, I had the front tires rebalanced. They thought maybe one of the balancing weights had fallen off. That did the trick. No more pulsating.
Old Apr 22, 2008 | 10:34 AM
robby363's Avatar
It sound like you need Hub Centric Rings, This will explain it.http://www.tirerack.com/wheels/tech/....jsp?techid=91
Old Apr 22, 2008 | 10:37 AM
SRT6 Dan's Avatar
Banned
Ditto, the hub maybe off center or balance. Check balance first or same time ask wheel shop about the hub fit !
Old Apr 22, 2008 | 10:51 AM
robby363's Avatar
Here's some more info.http://www.justforwheels.com/index.j...b=how&track=WM
Old Apr 22, 2008 | 11:50 AM
Reactivator's Avatar
Man - please - check your wheels nuts! I had the same problem on one car - when some stupid ahole forgot to tighten the nuts! Its so simply stupid - but thats maybe a reason.
(I wish you understand my english)
Old Apr 22, 2008 | 11:52 AM
SRT6 Dan's Avatar
Banned
Pretty good english for a Russian. I get it.
syfi
Mar 28, 2026 04:14 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
jimf
Oct 10, 2015 10:22 AM
ala_xfire
Sep 28, 2015 05:51 PM
